[mapserver-users] Problem trying to compile Mapserver 5.6.0 with
--with-experimental-png
Daniel Morissette
dmorissette at mapgears.com
Fri Jan 8 14:10:12 EST 2010
Try --with-png=/usr
You may have to provide valid paths for a few of the other configure
options. See "./configure --help" and/or README.CONFIGURE.
Also, it is better to turn on only the options that you require and not
try to blindly try to include every possible options without looking up
what they are about and which args they take.
Daniel
Luigi Castro Cardeles wrote:
> Hi List,
> i am trying to compile Mapserver 5.6.0 on a linux box with
> --with-experimental-png but the below message appears:
> checking if AGG support requested... checking if RGBA palette png
> support requested... configure: error: cannot find png headers in
> /root/app/mapserver-5.6.0/yes
> /root/app/mapserver-5.6.0 is the folder where i untar the mapserver tarball
> yes -> i don't know what is this :P
> Where i put the location of png headers?
> This is the command line:
> ./configure --enable-point-z-m --with-freetype --with-zlib --with-png
> --with-jpeg --with-xpm --with-libiconv --with-gd --with-pdf
> --with-agg=/usr --with-experimental-png --with-eppl --with-proj
> --with-threads --with-geos --with-ogr --with-gdal --with-tiff
> --with-postgis --with-ming --with-wfs --with-wcs --with-wmsclient
> --with-wfsclient --with-sos --with-curl-config --with-xml2-config
> --with-fribidi-config --with-cairo --with-fastcgi
> --with-php=/usr/include/php
> If i remove --with-experimental-png, i got this:
> --with-agg=/usr --with-eppl --with-proj --with-threads --with-geos
> --with-ogr --with-gdal --with-tiff --with-postgis --with-ming --with-wfs
> --with-wcs --with-wmsclient --with-wfsclient --with-sos
> --with-curl-config --with-xml2-config --with-fribidi-config --with-cairo
> --with-fastcgi --with-php=/usr/include/php
> -------------- Compiler Info -------------
> C compiler: gcc -O2 -fPIC -W -Wall -Wcast-align
> -Wmissing-prototypes -Wstrict-prototypes -Wpointer-arith -Wreturn-type
> -Wmissing-declarations
> C++ compiler: g++ -O2 -fPIC -W -Wall -Wcast-align
> Debug:
> Generic NINT:
> -------------- Renderer Settings ---------
> OpenGL support:
> zlib support: -DUSE_ZLIB
> png support:
> palette rgba png support:
> jpeg support:
> iconv support: -DUSE_ICONV
> AGG support: -DUSE_AGG
> Cairo (SVG,PDF) support: -DUSE_CAIRO
> Ming(flash) support: -DUSE_MING_FLASH
> PDFLib support: -DUSE_PDF
> -------------- Support Libraries ---------
> Proj.4 support: -DUSE_PROJ
> Libxml2 support: -DUSE_LIBXML2
> FriBidi support: -DUSE_FRIBIDI -DUSE_FRIBIDI2
> Curl support: -DUSE_CURL
> FastCGI support: -DUSE_FASTCGI
> Threading support: -DUSE_THREAD
> GEOS support: -DUSE_GEOS -DGEOS_HAS_SIMPLIFY
> -------------- Data Format Drivers -------
> native tiff support: -DUSE_TIFF
> PostGIS support: -DUSE_POSTGIS
> EPPL7 support: -DUSE_EPPL
> ArcSDE support:
> OGR support: -DUSE_OGR
> GDAL support: -DUSE_GDAL
> Oracle Spatial support:
> -------------- OGC Services --------------
> WMS Server: -DUSE_WMS_SVR
> WMS Client: -DUSE_WMS_LYR
> WFS Server: -DUSE_WFS_SVR
> WFS Client: -DUSE_WMS_LYR
> WCS Server: -DUSE_WCS_SVR
> SOS Server: -DUSE_SOS_SVR
> -------------- MapScript -----------------
> PHP MapScript: yes
> Any clue about this problem?
> Best Regard's
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
