[mapserver-users] New Mapserver install
bascom49
charles at weareland.com
Sun Jan 10 22:39:28 EST 2010
Andy Colson wrote:
> On 01/10/2010 08:55 PM, bascom49 wrote:
>> Andy Colson wrote:
>>> On 01/10/2010 04:11 PM, bascom49 wrote:
>>>> Ive installed mapserver on a vps server under centos 5 linux. I'm
>>>> having
>>>> problems with setting up mapscript.
>>>> My php setup is :
>>>> http://174.120.238.19/info.php
>>>> The output from mapserv -v is:
>>>> root at inf [/usr/local/apache/cgi-bin]# /usr/local/apache/cgi-bin/mapserv
>>>> -v
>>>> MapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>>>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
>>>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT
>>>> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS
>>>> INPUT=TIFF INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>>>> INPUT=SHAPEFILE
>>>> php_mapscript.so is located at:
>>>> /usr/local/lib/php/extensions/no-debug-non-zts-20060613/php_mapscript.so
>>>> I compiled mapserver 5.4.2 from source.
>>>> Can someone please help me trouble shoot my install ?
>>> I don't see a problem, or an error. So what do you need help with?
>>> -Andy
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> I expected to see a mapscript entry in the output from phpinfo(0),
>> similar
>> to
>> what is shown here :
>> http://www.londatiga.net/it/installing-mapserver-and-php-mapscript-on-linux/
>> Any insight that you may have is greatly appreciated.
>> Thanks,
>> Charles
> Ah, did you add an entry into the php.ini (in the extensions group)?
> -Andy
I added :
extension = “php_mapscript.so” to php.ini.
I did not add a new path entry as I had copied php_mapscript.so to the
default php extensions directory
that I saw listed from the output of phpinfo().
Is there something that I need to do to force php.ini to be reloaded ?
View this message in context: http://n2.nabble.com/New-Mapserver-install-tp4282833p4283679.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
