[mapserver-users] OWSRequest raw post data
Frank Broniewski
brfr at metrico.lu
Tue Jan 12 04:54:58 EST 2010
Hello list,
I am wondering how I could load / pass a raw post body to the owsrequest
object. GET is simply done with setParameter. I see that there is a
postrequest attribute for the owsrequest object, but there is no
documentation for it. Can I set it manually? I am using a WSGI Framework and
the documented req.loadParams() function does not work with it.
Or is there a parameter 'post' or 'xml' which I can set with the raw post
data with setParameter()?
Many Thanks
Frank
Frank Broniewski
Metrico s.àr.l. ( http://www.metrico.lu )
36, rue des Romains
L-5433 Niederdonven
Luxembourg
Fon: +352 26 74 94 28
Fax: +352 26 74 94 99
