[mapserver-users] OWSRequest raw post data
Frank Broniewski
brfr at metrico.lu
Tue Jan 12 10:26:24 EST 2010
Sorry, I forgot to mention that. I'm using Python ...
From: "Nolte, Tim" <Tim.Nolte at ipcswirelessinc.com>
Sent: Tuesday, January 12, 2010 3:56 PM
To: "Frank Broniewski" <brfr at metrico.lu>; <mapserver-users at lists.osgeo.org>
Subject: RE: [mapserver-users] OWSRequest raw post data
> What language are you using, is this PHP?
> - Tim
> Timothy J Nolte - tnolte at ilpcs.com
> Network Planning Engineer
> 4717 Broadmoor Ave, Suite G
> Kentwood, MI 49512
> Office: 616-656-5163
> PCS: 616-706-2438
> Support: 616-929-0289
> Fax: 616-554-6484
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Frank
> Broniewski
> Sent: Tuesday, January 12, 2010 4:33 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] OWSRequest raw post data
> Hello list,
> I am wondering how I could load / pass a raw post body to the owsrequest
> object. GET is simply done with setParameter. I see that there is a
> postrequest attribute for the owsrequest object, but there is no
> documentation for it. Can I set it manually? I am using a WSGI Framework
> and
> the documented req.loadParams() function does not work with it.
> Or is there a parameter 'post' or 'xml' which I can set with the raw post
> data with setParameter()?
> Many Thanks
> Frank
> Frank Broniewski
> Metrico s.àr.l. ( http://www.metrico.lu )
> 36, rue des Romains
> L-5433 Niederdonven
> Luxembourg
> Fon: +352 26 74 94 28
> Fax: +352 26 74 94 99
