[mapserver-users] Templates & JOIN object (one to many)
Ted Spradley
tspradley at snoogems.com
Tue Jan 12 23:15:51 EST 2010
Ok, I pieced the tidbits of info together. I thought I would go ahead and
post it all in one place in case anyone else is ever interested. I don't
know what I would do with out the postings in this list.
The bottom line is that the JOIN object and the LAYER object both require a
template directive. The
LAYER template functions only to redirect to the JOIN template. The
redirect is done with a template tag of the format: [join_joinname] (literal
word join followed by underscore then the JOIN object name).
The tags in the JOIN template have the format: [joinname_selectitem]. Here
they are in context.
Ted Spradley wrote:
> JOIN
> NAME "building_components"
> CONNECTION "dbname=cad1 user=user password=password host=localhost
> port=5432"
> CONNECTIONTYPE ogr
> TABLE "building_component_areas"
> FROM "hcad_num"
> TO "hcad_acct"
> TYPE ONE-TO-MANY
> TEMPLATE bldgCompGetFeatureInfo.html
> END
The JOIN object needs its own template defined.
TEMPLATE bldgCompGetFeatureInfo_join.html
Evidently when the layer is queried the function of the LAYER TEMPLATE
directive is to say 'Hey, process
JOIN "building_components" '.
Ted Spradley wrote:
> /* template bldgCompGetFeatureInfo.html */
> /* Mapserver Template */
> building_num =
> building_num.push('[building_components_building_num]');
> building_component =
> building_component.push('[building_components_building_component]');
> area = area.push('[building_components_area]');
should be:
[join_building_components]
and then you need the template for the JOIN object with errors corrected in
the js:
/* template bldgCompGetFeatureInfo_join.html */
Ted Spradley wrote:
> /* template bldgCompGetFeatureInfo_footer.html */
> <!-- Mapserver Template -->
> /* Write out the table by accessing the arrays */
> document.write("
> <table id=\"bldg_comp_areas\">
> <tr>
> <th colspan=\"2\">Building Details</th>
> </tr>
> <tr>
> <td>Building Number</td>
> <td>Building Component</td>
> <td>Area</td>
> <td>units</td>
> </tr>"
> for(key in building_num){
> document.write("<tr><td>" + building_num[key] + "</td><td>" +
> building_component[key] + "</td><td>" + area[key] + "</td><td>" +
> "sq ft");
> document.write("
> </table>
> <br />
should be:
document.write("<table id='bldg_comp_areas'><tr><th colspan='4'>Building
Details</th></tr><tr><td>Building Number</td><td>Building
Component</td><td>Area</td><td>units</td></tr>");
"sq ft" + "</td></tr>");
document.write("</table><br />");
</script>
The result is a table listing all of the building components.
Building Details
Building Number Building Component Area units
1 ONE STORY MAS UPR 24 sq ft
1 OPEN MAS PORCH PRI 24 sq ft
1 BASE AREA PRI 1164 sq ft
1 MAS/BRK GARAGE PRI 400 sq ft
1 OPEN MAS PORCH PRI 16 sq ft
1 BASE AREA UPR 1164 sq ft
1 ONE STORY FRAME PRI 60 sq ft
1 ONE STORY MAS UPR 400 sq ft
1 OPEN MAS PORCH PRI 31 sq ft
This will work using GetFeatureInfo in the URL, but if you are accessing
your WMS with OpenLayers, you are already in a javascript, so you need to
use straight html in your templates.
/* template bldgCompGetFeatureInfo_header.html */
<!-- No javascript, must be straight html to handle output -->
<table>
<tr>
<td colspan="4">Building Details</td>
</tr>
<tr>
<td>Area</td>
<td>Units</td>
</tr>
<tr>
<td>[building_components_building_num]</td>
<td>[building_components_building_component]</td>
<td>[building_components_area]</td>
<td>sq ft</td>
</tr>
</table>
Cheers everybody! Hope it helps someone.
Gracias a todo!
Ted S
MapServer version 5.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Linux/Fedora7
View this message in context: http://n2.nabble.com/Templates-JOIN-object-one-to-many-tp4293738p4306948.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
