[mapserver-users] symbol circle (ellipse) rendered not round
but oval
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Wed Jan 13 09:46:20 EST 2010
Oliver,
Apologies for sending you down the wrong path. I don't follow the dev list, so I am not up on the latest feature opportunities (and pitfalls). My solutions appear to be aimed at things people have already figured out...
David.
From: Oliver Christen [mailto:oliver.christen at camptocamp.com]
Sent: Wednesday, January 13, 2010 3:05 AM
To: Fawcett, David (MPCA)
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] symbol circle (ellipse) rendered not round but oval
hi David
Im requesting the image through wms indeed.
Though the bbox x/y ratio is exactly the same as the image x/y.
I tried to request the same image directly in cgi, sadely I get exactly the same problem:
image result in cgi: http://dev.camptocamp.com/~ochriste/cgi.png
(as compared to the wms image http://dev.camptocamp.com/~ochriste/wms.png)
this is the cgi request I used:
/usr/lib/cgi-bin/mapserv -nh "QUERY_STRING=map=/var/www/veloland/private/veloland/veloland/wms/veloland.map&mode=map&LAYERS=MtblandRoutenNational&mapext=556960+220720+557600+221360&mapsize=256+256" > cgi.png
I used exactly the same bbox and image size as the wms request:
/wms?FORMAT=image%2Fpng&LAYERS=MtblandRoutenNational&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A21781&BBOX=556960,220720,557600,221360&WIDTH=256&HEIGHT=256
this is when using STYLE 1 20 END or PATTERN 1 20 END for the symbol
when using GAP the dots are correctly shaped
so I suspect the problem is within the interpretation of STYLE/PATTERN for the symbol generation ?
2010/1/12 Fawcett, David (MPCA) <David.Fawcett at state.mn.us<mailto:David.Fawcett at state.mn.us>>
Are you requesting your image through a WMS and maybe getting a 'non-square pixel' effect?
If you are using WMS, are the symbols round when you do a cgi request in mode=map or mode=tile?
David.
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>] On Behalf Of Oliver Christen
Sent: Tuesday, January 12, 2010 9:31 AM
To: thomas bonfort
Cc: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Hi Thomas :)
thanks for the answer, but sadely it didnt solve my problem:
here are a few tests I did:
using GAP 20 gave me really weird result:
http://dev.camptocamp.com/~ochriste/tilecache6_gap_20.png<http://dev.camptocamp.com/%7Eochriste/tilecache6_gap_20.png>
using PATTERN 1 22 END gave me better result, but the dot are still slightly oval:
http://dev.camptocamp.com/~ochriste/tilecache7_pattern.png<http://dev.camptocamp.com/%7Eochriste/tilecache7_pattern.png>
I wondered if the visual effect may have come from the fact im pilling up two circle one over the other, but even when trying to display only the outer or inner circles, the circle are still slightly off:
http://dev.camptocamp.com/~ochriste/tilecache4_outercircle.png<http://dev.camptocamp.com/%7Eochriste/tilecache4_outercircle.png>
http://dev.camptocamp.com/~ochriste/tilecache5_innercircle.png<http://dev.camptocamp.com/%7Eochriste/tilecache5_innercircle.png>
(both at once http://dev.camptocamp.com/~ochriste/tilecache3_bothcircle.png<http://dev.camptocamp.com/%7Eochriste/tilecache3_bothcircle.png>)
any other idea? ^_^
----- Original Message -----
From: thomas bonfort<mailto:thomas.bonfort at gmail.com>
To: Oliver Christen<mailto:oliver.christen at camptocamp.com>
Sent: Tuesday, January 12, 2010 3:18 PM
hi Oliver :)
try with GAP 20 instead of STYLE 1 20 END (which is deprecated btw, use PATTERN now)
cheers,
thomas
On Tue, Jan 12, 2010 at 15:04, Oliver Christen <oliver.christen at camptocamp.com<mailto:oliver.christen at camptocamp.com>> wrote:
hello
I have a weird problem with symbology.
Im rendering a line with dots, but the dots are not round but slightly oval, see image http://dev.camptocamp.com/~ochriste/tilecache.png<http://dev.camptocamp.com/%7Eochriste/tilecache.png>
Any idea what could be the cause ?
Here is my symbol definition:
SYMBOL
NAME "linie-gepunkt10"
TYPE ELLIPSE
POINTS
1 1
END
STYLE
1 20
END
FILLED TRUE
END
and my layer's class definition:
CLASS
EXPRESSION "3"
MAXSCALEDENOM 200001
STYLE
SYMBOL "linie-gepunkt10"
SIZE 10
COLOR 102 51 0
END
STYLE
SIZE 8
COLOR 204 102 0
END
END
and the map outputformat:
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
END
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100113/de1bad76/attachment.html
