[mapserver-users] symbol at start and end of polyline ?
Oliver Christen
oliver.christen at camptocamp.com
Tue Jan 19 09:12:57 EST 2010
At first I thought I had some oddity with the data I used for my testing
( see http://dev.camptocamp.com/~ochriste/line_with_style.png with the star symbol on every vertex of one line feature)
but after trying with some other set of data, I only have the star symbol on start and end of the whole line feature ( and, strangely, also on cross-section if the line separate in two at some point )
http://dev.camptocamp.com/~ochriste/line_feature_extremities.png
so I thought the problem was solved, but upon zooming on the extrmities of the line feature, im again having strange behavior:
http://dev.camptocamp.com/~ochriste/line_feature_extremity_zoomed.png
with multiple star symbols.
the red star in these two image are from the same line feature.
why is there more than 2 stars ?
does the geomtransform 'end' only work for line features consisting of only 2 points ?
----- Original Message -----
To: Oliver Christen
Cc: mapserver-users at lists.osgeo.org
Sent: Tuesday, January 19, 2010 2:10 PM
Subject: Re: [mapserver-users] symbol at start and end of polyline ?
if you're using postgis, you can use a unique key from your table (i.e. gid)
if you have a shapefile, you'll have to find an or a combination of attributes in the dbf that's unique to identify that particular feature.
thomas
On Tue, Jan 19, 2010 at 11:59, Oliver Christen <oliver.christen at camptocamp.com> wrote:
it makes sens, but how do I do that ?
do line segment get automaticaly an id ?
or how to get (or set) the id of the line segment?
To: Oliver Christen
Sent: Tuesday, January 19, 2010 10:50 AM
well, if you want only one line segment to have start markers, you must tell mapserver which segment that is.
On Tue, Jan 19, 2010 at 10:48, Oliver Christen <oliver.christen at camptocamp.com> wrote:
thx Thomas, but im not sure I understand what you are telling me here.
do line segments have id ?
To: Oliver Christen
Sent: Tuesday, January 19, 2010 10:30 AM
hi,
class
expression ([id]=321)
style
geomtransform end
end
end
class
style
... #all the others
end
end
On Tue, Jan 19, 2010 at 10:14, Oliver Christen <oliver.christen at camptocamp.com> wrote:
hello
I would like to add a symbol at the start and end of a polyline.
I tried using GEOMTRANSFORM with "start" and "end" in a style block in the layer but sadely this will add a symbol to all start and end of every vertex of the polyline, which is not the result wanted :/
is there any way to do that, beside creating a new point layer ?
thanks in advance
Oliver
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100119/0f265a05/attachment-0001.html
