[mapserver-users] VRT / CSV data sources are not displayed in a
layer
Frank Warmerdam
warmerdam at pobox.com
Thu Jan 21 20:49:50 EST 2010
Stefan,
I would suspect that your .vrt file contains relative rather
than absolute paths and that they are relative to a
different working directory if used from MapServer.
There is an attribute for the <SrcDataSource> that
may address this. It might help if you posted the
VRT.
2010/1/20 Stefan Schantz <SSchantz at bfs.de>:
> Hello List,
> The following layer uses a CSV-file (together with a VRT-File (Virtual
> Format) ) as datasource . When I try to visualize the layer, nothing is
> shown (neither the data nor error messages; shp2img shows also nothing)
> LAYER
> NAME "boden"
> DEBUG on
> STATUS ON
> TYPE POINT
> # DATA "/daten/csv/boden/boden" # Datenquelle Shapefile
> CONNECTION "/daten/csv/boden.vrt"
> CONNECTIONTYPE OGR
> PROJECTION
> "init=epsg:25832"
> END
> METADATA
> "WMS_TITLE" "test"
> "WMS_SRS" "EPSG:25832"
> "WMS_ABSTRACT" "test"
> "WMS_FEATURE_INFO_MIME_TYPE" 'text/html'
> END
> CLASS
> NAME "test"
> STYLE
> SYMBOL "circle"
> SIZE 15 COLOR 90 90 90
> END
> END END
> But if I transform the CSV/VRT-file into a Shapefile via ogr2ogr
> ogr2ogr -s_srs EPSG:25832 -t_srs EPSG:25832 -f "ESRI Shapefile" boden
> boden.vrt
> the layer displays the data.
> What is wrong with my VRT/CSV-datasource in the mapfile?
> Thanks for any idea.
> Best regards
> Stefan
> mapserver-users at lists.osgeo.org
and watch the world go round - Rush | Geospatial Programmer for Rent
