[mapserver-users] GRASS GIS layers -help!
Gazz1982
garynobles at yahoo.com
Fri Jan 22 05:10:04 EST 2010
I am using GRASS GIS with gdal and ogr support:
mapserv -v
MapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Mapserver works with no problems with shapefiles
I tried to link to a GRASS layer using the following layer definition and it
returned this error:
msDrawMap(): Image handling error. Failed to draw layer named 'ex_area'.
msShapefileOpen(): Unable to access file.
(/var/www/grassdata/Keinsmerburg2/site_data/ex_area/1_polygon)
File permissions are set to www-data and are set to create and delete.
Any ideas? I would be very grateful
Gary
LAYER
NAME 'ex_area'
TYPE POLYGON
DUMP true
TEMPLATE fooOnlyForWMSGetFeatureInfo
EXTENT -30.311890 -1.325000 68.311890 54.325000
DATA '/var/www/grassdata/Keinsmerburg2/site_data/ex_area/1_polygon'
METADATA
'ows_title' 'ex_area'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=sterea'
'lat_0=52.15616055555555'
'lon_0=5.38763888888889'
'k=0.9999079'
'x_0=155000'
'y_0=463000'
'ellps=bessel'
'units=m'
'no_defs'
END
CLASS
NAME 'ex_area'
STYLE
SYMBOL 0
SIZE 7.0
OUTLINECOLOR 0 0 0
COLOR 64 113 156
END
END
END
View this message in context: http://n2.nabble.com/GRASS-GIS-layers-help-tp4439193p4439193.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
