[mapserver-users] Projection error, RT90 in MapServer
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Jan 22 05:16:40 EST 2010
Have you tried adding 'towgs84=0,0,0,0,0,0,0' also to RT90 definitions?
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Fia
> Lähetetty: 22. tammikuuta 2010 10:56
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Projection error, RT90 in MapServer
> Hello,
> I have a problem showing data in the former Swedish standard reference
> system RT90 2,5 gon V. The point is projected ~250 meters
> northwest of where
> it should be. I have used the projection parameters for MapServer from
> Spatialreference.org.
> The underlying map projection is SWEREF 99 TM (the new
> standard Swedish
> reference system), with the following projection parameters:
> PROJECTION
> 'proj=utm'
> 'zone=33'
> 'ellps=GRS80'
> 'units=m'
> 'no_defs'
> END
> I have then tested to pinpoint an intersection, in both
> WGS-84 and RT90, but
> the RT90 point does not end up where it should be. I have
> double checked
> that the RT90 coordinates are correct by transforming them to
> WGS-84. See my
> attached screenshot.
> http://n2.nabble.com/file/n4438959/rt90_mapserver_error.jpg
> For the WGS-84 point I have the following projection parameters:
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> 'units=m'
> END
> And the RT90 point has:
> PROJECTION
> "proj=tmerc"
> "lat_0=0"
> "lon_0=15.80827777777778"
> "k=1"
> "x_0=1500000"
> "y_0=0"
> "ellps=bessel"
> "units=m"
> "no_defs"
> END
> I have also tried all the other RT90 projections provided by
> Spatialreference.org, just to see if any of them would work
> better, but
> without luck.
> Have I made a mistake somewhere, or are there any suggestions
> of why this
> error occurs? I'm out of ideas.
> Regards,
> Sofia
> http://n2.nabble.com/Projection-error-RT90-in-MapServer-tp4438
> 959p4438959.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
