hi
I have a mapserver 5.2.1 on a server which totally ignore the DATA in a
postgis layer definition in my mapfile.
I can write anything I want, even gibberish, in the DATA without even geting
an error.
This is my layer :
LAYER
NAME "plan_points"
STATUS ON
TYPE POINT
CONNECTIONTYPE POSTGIS
CONNECTION "dbname=sitn user=plans_intervention
password=sitn_plans_intervention host=nesitn2"
#DATA 'geom from (select
geom,oid,id,fk_obj,code,com,sf,op_saisie,rem,rotation,url_lien,owner from
plans_intervention.plan_points) as foo'
#DATA "geom from (select * from test.plan_points) as foo using unique id"
DATA "dfsdfsdfd"
TEMPLATE "ttt"
OPACITY 100
CLASSITEM "code"
TOLERANCE 20
CLASS
STYLE
SYMBOL "background1"
SIZE 20
COLOR 255 255 255
ANGLE [rotation]
END
STYLE
SYMBOL "VHC1"
SIZE 20
COLOR 0 0 255
ANGLE [rotation]
END
TEXT ([com])
LABEL
COLOR 0 0 255
OUTLINECOLOR 255 255 255
FONT "arial"
TYPE truetype
SIZE 12
ANGLE [rotation]
POSITION uc
PRIORITY 10
PARTIALS FALSE
FORCE true
ANTIALIAS true
END
END
END
as you can see I have made different try for the DATA, all are ignored, even
the DATA "dfsdfsdfd" one.
the server is running on Windows Server 2008
any idea why the DATA string is ignored ?
this is the full mapserver version info:
MapServer Version MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE PHP MapScript Version ($Revision: 7937 $ $Date:
2008-09-30 10:37:46 -0400 (Tue, 30 Sep 2008) $)
thanks in advance
Oliver
