[mapserver-users] queryByAttributes syntax
Berend Veldkamp
b.veldkamp at zonnet.nl
Mon Jan 25 06:57:17 EST 2010
Thanks, I'll try this.
Berend
On 1/22/10, Lime, Steve D (DNR) <Steve.Lime at state.mn.us> wrote:
> There's a single way to call the method, it's that you don't always have to
> supply the query item. The method signature is
> queryByAttributes (map (mapObj, qitem (string), qstring (string), mode
> (int));
> The qstring is given in a format compatible with the underlying driver. For
> the database drivers it's basically a where-clause. For others
> you use MapServer expression syntax. Some expression types (e.g. string
> matches or regex) require the qitem.
> To do a partial match you could use a regex, for example:
> layer.queryByAttributes(map, "myfield", "/myregex/",
> mapscript.MS_MULTIPLE);
> Steve
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Berend
> Veldkamp
> Sent: Friday, January 22, 2010 6:22 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] queryByAttributes syntax
> Hi,
> Where can I find more information about the queryByAttributes() function? I
> found http://mapserver.org/mapscript/php/index.html#layerobj-class , but it
> is not very detailed. By trial and error I found that for a PostGIS layer, I
> should use this syntax:
> layer.queryByAttributes(map, null, "myfield='searchValue'",
> but for shapefiles, it seems it should be:
> layer.queryByAttributes(map, "myfield", "searchValue",
> I am trying to write some generic code, but that's hard if there is no
> single way to call this method. Also, I haven't found a way yet to do a
> partial match on a shapefile (PostGIS supports 'LIKE')
> Regards,
> Berend Veldkamp
