[mapserver-users] resolution
Valeria Muñoz
valemunoz at gmail.com
Mon Jan 25 10:44:25 EST 2010
Hi Alan
i did set defresolution to 72 ,but return to me this error.
msLoadMap(): Unknown identifier. Parsing error near (DEFRESOLUTION):(line 7)
in what MapSever version can i define DEFRESOLUTION?
RG
2010/1/25 Alan Boudreault <aboudreault at mapgears.com>
> Hi
> Set the DEFRESOLUTION to 72 (I assume all your mapfile settings are for a
> 72dpi image) , change the RESOLUTION to 300. Change your map size if you
> want
> a big 300dpi image.
> It is possible that the image header doesn't contain the DPI information.
> This
> can easily be modified with a graphic program like "The GIMP".
> Alan
> On January 25, 2010 10:00:52 am Valeria Muñoz wrote:
> > Hi
> > I need to produce a 300dpi image for printing, i defined a RESOLUTION
> > 300 in the mapfile , but nothing happens , still in 72 dpi ... can you
> help
> > me please?
> > mapfile
> > MAP
> > NAME neonline_mapa
> > RESOLUTION 300
> > SIZE 400 400
> > UNITS dd
> > SHAPEPATH "c:/ms4w/Apache/htdocs/test_mapfile/dataB2/"
> > EXTENT -112.888238 -57.06133625 -7.419488000000001 13.25116375
> > FONTSET "c:/ms4w/Apache/htdocs/test_map_dis/fonts/fonts.txt"
> > PROJECTION
> > 'proj=longlat'
> > 'ellps=WGS84'
> > 'datum=WGS84'
> > 'no_defs'
> > END
> > IMAGECOLOR 122 206 232
> > OUTPUTFORMAT
> > NAME png
> > DRIVER "AGG/PNG"
> > MIMETYPE 'image/png'
> > IMAGEMODE RGB #RGBA transparente
> > EXTENSION "png"
> > FORMATOPTION "TRANSPARENT=ON"
> > FORMATOPTION "INTERLACE=ON"
> > FORMATOPTION "QUANTIZE_COLORS=256"
> > END
> > # Legend
> > LEGEND
> > IMAGECOLOR 255 255 255
> > STATUS ON
> > KEYSIZE 18 12
> > LABEL
> > TYPE BITMAP
> > SIZE MEDIUM
> > COLOR 0 0 89
> > END
> > END
> Alan Boudreault
> Mapgears
> http://www.mapgears.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100125/7c029818/attachment.html
