[mapserver-users] Re: WMSGetFeatureInfo problem (No results,
using OL)
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Jan 27 03:09:01 EST 2010
Did you try to find the problem first? You seem to run your own Mapserver. Then you can see from the Apache access log the requests that your client is actually sending. MS4W installation the log file is by default at ms4w\apache\logs\access.log
Add DEBUG 5 into LAYER definitions in your mapfile. Copy and paste some failing GetFeatureInfo request from access log and resent it with web browser. See what comes back, and have a look at the Mapserver errorfile which collects the DEBUG data. It might be better to send GetFeatureInfo requests first against polygon layer because then it is easier to hit a feature by mouse click. By hand editing the request you will have a full control in what happens. When you know that the system works with browser you can trust that Mapserver side is OK and you can continue to OpenLayers or other clients.
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta stela anders
Lähetetty: 26. tammikuuta 2010 21:33
Vastaanottaja: MapserverList OSGEO
Aihe: [mapserver-users] Re: WMSGetFeatureInfo problem (No results,using OL)
Any idea whats happening?
I lost all day trying to fix that, but got nothing :(
Stella
2010/1/25 stela anders <stelaanders at gmail.com>
Hello guys...
My mapfile:
PROJECTION
"+init=epsg:4326"
END
WEB
IMAGEPATH 'C:\temp\'
IMAGEURL '/tmp/'
QUERYFORMAT text/html
METADATA
"wms_title" "WMS Server"
"wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe?"
"wms_srs" "EPSG:4326 EPSG:42304 EPSG:42101 EPSG:4269"
'wms_feature_info_mime_type' "text/html"
END
END
QUERYMAP
COLOR 255 0 0
SIZE -1 -1
STATUS OFF
STYLE hilite
END
LAYER
METADATA
"wms_title" "Test" ##required
"wms_include_items" "all"
"wms_feature_info_mime_type" "text/html"
END
TYPE POINT
STATUS ON
INCLUDE "Connection.map"
DATA "the_geom from viwtest USING UNIQUE oid USING SRID=0"
PROJECTION
"+init=epsg:4326"
END
TOLERANCE 5
HEADER "header.html"
TEMPLATE "template.html"
FOOTER "footer.html"
Templates:
Header.html
<!-- MapServer Template -->
<html>
<head>
<title>MapServer Template Sample</title>
</head>
Template.html
<body>
<b>OID:</b> [oid]
</body>
Footer.html
</html>
WMSGetFeatureInfo Javascript (OpenLayer)
var infoCtl = new OpenLayers.Control.WMSGetFeatureInfo({
layers: [_test],
title: 'Click on the map to get information on layers',
queryVisible: true,
infoFormat: 'text/html'
infoCtl.events.register("getfeatureinfo",map,showInfo);
function showInfo(evt) {
alert(evt.text);
I´m getting that :
<html>
<head>
</head> Content-type: application/vnd.ogc.se_xml
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
</ServiceException>
</ServiceExceptionReport>
Stella
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100127/747bb241/attachment-0001.html
