[mapserver-users] Re: WMSGetFeatureInfo problem (No results,
using OL)
Paul james
pauljame at gmail.com
Wed Jan 27 11:00:48 EST 2010
Hi !
I dont think that it is the problem, because WMSGetFeatureInfo is generating
the "correct" url (I think)...
Anyway I tested querying only 1 single layer and got the same result...
Dammit :(
Thanks anyway
Stella
On Wed, Jan 27, 2010 at 12:24 PM, Eichner, Andreas - SID-NLKM <
Andreas.Eichner at sid.sachsen.de> wrote:
> Hi Stella,
> according to
> http://dev.openlayers.org/docs/files/OpenLayers/Control/WMSGetFeatureInfo-js.htmlthe WMSGetFeatureInfo control's constructor takes an array of
> OpenLayers.Layer.WMS objects. But you give it the list you used to draw as
> one layer. So you should create two OpenLayers.Layer.WMS objects, one for
> layer "Test1" and one for "Test2" and then give the control an array of
> them.
> So if I'm correct it should look something like that:
> var _test1 = new OpenLayers.Layer.WMS(
> "MyLayer 1",
> _mapfilex,
> layers: [ 'Test1'],
> format: "image/png",
> transparent: "true"
> isBaseLayer: false,
> buffer: 0,
> visibility: true
> var _test2 = new OpenLayers.Layer.WMS(
> "MyLayer 2",
> _mapfilex,
> layers: [ 'Test2'],
> transparent: "true"
> isBaseLayer: false,
> buffer: 0,
> visibility: true
> var infoCtl = new OpenLayers.Control.WMSGetFeatureInfo({
> layers: Array(_test1, _test2),
> title: 'Click on the map to get information on
> layers',
> queryVisible: true,
> infoFormat: 'text/html'
> infoCtl.events.register("getfeatureinfo",map,showInfo);
> function showInfo(evt) {
> alert(evt.text);
> Also I don't know how MapServer handles queries to two or more layers if at
> least one of them declares header or footer - it might happen that a layer
> without a header is processed before one with. And from what you got back I
> suggest that MapServer processes each layer if it was queried alone and
> therefore outputs the HTTP "Content-type" header after processing the first
> layer.
> Mit freundlichen Grüßen,
> Andreas Eichner
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100127/7e0ab8d1/attachment.html
