[mapserver-users] mapserver 5.4.2 Reprojection error
tommaso
tommasodb at googlemail.com
Fri Jan 29 11:37:02 EST 2010
On Tue, 2010-01-26 at 15:13 +0200, Rahkonen Jukka wrote:
> Hi,
> I am not sure if this helps in your case, but you can try to edit the
> "epsg" file in the projection library and add +towgs84=0,0,0 in the
> line that defines the <31467> projection. EPSG:3067 needs this extra
> parameter for sure and I believe it is the same with your next try
> with EPGS:32632. Let's hope it cures 31467 as well.
> -Jukka Rahkonen-
It seems to work with both EPGS:31467 and EPGS:32632, thanks again.
Is it a bug in Mapserver, it isn't ? should I report a bug?
greets,
Tom
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100129/542f2fde/attachment.html
