[mapserver-users] mapserver documentation: unique gid using srid=x ?
Ivan Mincik
ivan.mincik at gista.sk
Fri Jan 29 12:07:21 EST 2010
according Mapserver docs: http://mapserver.org/input/vector/postgis.html there is different syntax of using "USING
UNIQUE gid USING SRID=x" string in DATA line in similar cases.
In simple case example:
DATA "the_geom from the_database USING unique gid using srid=4326"
In case of using a SQL subquery example:
DATA "the_geom from (select g.gid, g.the_geom, a.attr1, a.attr2 from geotable g join attrtable a on g.gid = a.aid) as
subquery unique gid using srid=4326"
When comparing these two examples, second example (SQL subquery example) is missing first "USING" keyword. Shouldn't be
second example as following:
subquery USING unique gid using srid=4326"
Thanks
Ivan
Name: not available
Desc: This is a digitally signed message part.
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100129/0b5e2b18/attachment.bin
