[mapserver-users] How to serve individual RAW binary Bands
fromWCS as floating point geotiff
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Fri Jan 29 17:54:14 EST 2010
Is this link of help?
http://mapserver.org/input/raster.html#special-processing-directives
There's a directive to extract a single band from an n-band image...
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Peter Willis
Sent: Friday, January 29, 2010 10:41 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] How to serve individual RAW binary Bands fromWCS as floating point geotiff
Hello,
Interesting... The documentation indicates:
&RangeSubset=contents:nearest[Band[120]]
I tried what you suggest but continue to have the same problem.
The mapserver *did not* complain about '&RESAMPLE=BILINEAR&Band=120'
so I guess we can assume that those parameters work.
Peter
Rahkonen Jukka wrote:
> Hi,
> I have never used this myself: &RangeSubset=contents:nearest[Band[120]]
> Is that WCS 1.0.0 parameter? For selecting bands from WCS 1.0.0 service I have been using something like
> &RESAMPLE=BILINEAR&Band=4
> -Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Peter Willis
> Lähetetty: pe 29.1.2010 0:26
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] How to serve individual RAW binary Bands fromWCS as floating point geotiff
> Hello,
> The definition of GEOTIFF_FLOAT is as follows:
> OUTPUTFORMAT
> NAME GEOTIFF_FLOAT
> DRIVER "GDAL/GTiff"
> MIMETYPE "application/octet-stream"
> IMAGEMODE FLOAT32
> END
> I Added the MIMETYPE as shown to ensure that web browsers
> would ask to save the file rather than just open it in an
> image viewer from a temp file. (MS Windows...)
> That part works fine.
> Mostly I am concerned with extracting a specific 'band'
> from the multi-band file. The server serves floating point
> geotiff just fine.
> Peter
>> Hi,
>> How have you defined the OUTPUTFORMAT for GEOTIFF_FLOAT?
>> -Jukka Rahkonen-
>> Peter Willis wrote:
>>> Hello,
>>> I have been setting up a WCS map file for mapserver.
>>> PROBLEM:
>>> Problems arise when rasters are defined
>>> as follows:
>> LAYER
>> NAME SomeDataChannel120
>> STATUS OFF
>> DEBUG ON
>> TYPE RASTER ### required
>> PROCESSING "BANDS=120"
>> METADATA
>> "wcs_label" "Data/stuff"
>> "wcs_rangeset_name" 'bands'
>> "wcs_rangeset_label" "Stuff thats mapped"
>> "ows_extent" '-135 55 -121 46'
>> "wcs_resolution" '0.08333333333333332 -0.083333333333333332'
>> "ows_srs" 'EPSG:4326'
>> "wcs_srs" 'EPSG:4326'
>> "wcs_formats" 'GEOTIFF_FLOAT,GEOTIFF_INT16'
>> "wcs_nativeformat" 'ENVI'
>> # "wcs_bandcount" '563'
>> "wcs_rangeset_axes" 'bands'
>> END
>> DATA /data/stuff.img
>> PROJECTION
>> "init=epsg:4623"
>> END
>> DUMP TRUE ### required
>> END
>> I have 'wcs_bandcount' commented out because mapserver
>> causes an internal error in the web server if I define the
>> band count.
>> I get floating point geotiff served with the following client request:
>> http://sparky.com/cgi-bin/wcs?REQUEST=GetCoverage&SERVICE=WCS&VERSION=1.0.0&COVERAGE=SomeDataChannel120&CRS=EPSG:4326&BBOX=-135,55,-121,46&WIDTH=432&HEIGHT=216&FORMAT=GEOTIFF_FLOAT&RangeSubset=contents:nearest[Band[120]]
>> ..however, I always only get the first band from the img file....
>> QUESTIONS:
>> Is there a problem with this setup?
>> Do I need to define each band as a layer in the mapfile
>> or will mapserver WCS allow the client to request a single
>> channel?
>> Thanks for any enlightenment,
>> Peter
