[mapserver-users] mapserver + grib files + explanation and questions
Muro
muraro_davide at hotmail.com
Thu Jul 1 09:50:29 EDT 2010
Hello,
After some time I was able to process grib v.1 format using
MapServer+gdal+OL 2.9.
I see the requested band and I get the point-clicked-value using
OL-getfeatureinfo.
My mapfile:
LAYER
NAME 'EUD201006_cp-lsp'
DATA '/var/www/html/netcdf/mapserver/data/EUD201006_cp-lsp.grb'
TYPE RASTER
DUMP true
TOLERANCE 10
TOLERANCEUNITS DD
HEADER "templates/getfeatureinfo_header.html" # header html template
TEMPLATE "templates/getfeatureinfo_content.html" # content html template
FOOTER "templates/getfeatureinfo_footer.html" # footer html template
METADATA
'ows_title' 'EUD201006_cp-lsp.grb'
'wms_feature_info_mime_type' "text/html"
"gml_include_items" "all"
"wms_include_items" "all"
END
STATUS OFF
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
#PROCESSING "DITHER=YES"
#PROCESSING "BANDS=30,24,4"
PROCESSING "BANDS=6136"
#PROCESSING "BANDS=30,50,70,90,110"
#0.070106506 = 70 mm
CLASS
NAME "0.00 to 0.07"
EXPRESSION ([pixel] >= 0 AND [pixel] < 0.005)
STYLE
COLOR 205 250 100
END
END
CLASS
NAME "0.07 to 0.14"
EXPRESSION ([pixel] >= 0.005 AND [pixel] < 0.01)
STYLE
COLOR 145 240 67
END
END
CLASS
NAME "0.14 to 0.20"
EXPRESSION ([pixel] >= 0.015 AND [pixel] < 0.02)
STYLE
COLOR 88 230 32
END
END
CLASS
NAME "0.20 to 0.27"
EXPRESSION ([pixel] >= 0.02 AND [pixel] < 0.025)
STYLE
COLOR 62 209 54
END
END
CLASS
NAME "0.27 to 0.34"
EXPRESSION ([pixel] >= 0.025 AND [pixel] < 0.03)
STYLE
COLOR 61 186 101
END
END
CLASS
NAME "0.34 to 0.41"
EXPRESSION ([pixel] >= 0.03 AND [pixel] < 0.035)
STYLE
COLOR 49 163 144
END
END
CLASS
NAME "0.41 to 0.48"
EXPRESSION ([pixel] >= 0.035 AND [pixel] < 0.04)
STYLE
COLOR 30 134 166
END
END
CLASS
NAME "0.48 to 0.54"
EXPRESSION ([pixel] >= 0.04 AND [pixel] < 0.045)
STYLE
COLOR 33 88 150
END
END
CLASS
NAME "0.54 to 0.61"
EXPRESSION ([pixel] >= 0.045 AND [pixel] < 0.05)
STYLE
COLOR 28 52 135
END
END
CLASS
NAME "0.61 to 0.68"
EXPRESSION ([pixel] >= 0.05 AND [pixel] < 0.055)
STYLE
COLOR 13 17 120
END
END
CLASS
NAME "0.61 to 0.68"
EXPRESSION ([pixel] >= 0.055)
STYLE
COLOR 255 0 255
END
END
END
OpenLayers code:
var wmsOptions = {
layers: 'EUD201006_cp-lsp',
//layers: 'EUD2010060100, vol_soil_water',
format: 'image/png',
maxExtent: maxExtentDD,
transparent: 'true'
gribLayer = new OpenLayers.Layer.WMS( 'wms grib layer', geoserver ,
wmsOptions, {isBaseLayer:true, buffer:0, displayInLayerSwitcher:true });
map.addLayer(gribLayer);
map.addControl( new OpenLayers.Control.LayerSwitcher() );
map.events.register('click', map, function (e)
OpenLayers.Util.getElement('nodeList').innerHTML = "Loading... please
wait...";
var url = gribLayer.getFullRequestString({
REQUEST: "GetFeatureInfo",
EXCEPTIONS: "application/vnd.ogc.se_xml",
BBOX: gribLayer.map.getExtent().toBBOX(),
X: e.xy.x,
Y: e.xy.y,
INFO_FORMAT: 'text/html',
QUERY_LAYERS: gribLayer.params.LAYERS,
WIDTH: gribLayer.map.size.w,
HEIGHT: gribLayer.map.size.h});
OpenLayers.loadURL(url, '', this, setHTML);
OpenLayers.Event.stop(e);
Is possible to do a getfeatureinfo for all bands?
If I use PROCESSING "BANDS=30,24,4", I get 3 values (correctly)
Reading the documentation (http://mapserver.org/input/raster.html#raster) is
possible to query more than RGB-opaque (4 bands)
[CUT]
The red, green and blue attribute are intended to be the final color the
pixel would be rendered with, but in some subtle cases it can be wrong (ie.
classified floating point results). The selected bands are normally the band
that would be used to render the layer. For a pure query-only layer BANDS
PROCESSING directive can be used to select more bands than could normally be
used in a render operation. For instance for a 7 band landsat scene a
PROCESSING “BANDS=1,2,3,4,5,6,7” directive could be used to get query
results for all seven bands in results to a query operation.
[/CUT]
I mean, when I click on a point I need to get all values associated to that
point.
There are 6136 bands in my grib file.
I removed PROCESSING "BANDS=6136", but mapserver crashes (500 internal
error...mm no good)
I added PROCESSING "BANDS=10,20,30,40,50", but mapserver crashes (500
internal error)
Ideas? Is it possible?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/mapserver-grib-files-explanation-and-questions-tp5243456p5243456.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
