[mapserver-users] problem installing mapscript
Worth Lutz
wal3 at mindspring.com
Sun Jul 4 15:33:00 EDT 2010
Thanks for response. I'm not new to Mapserver. I've been using it for over
a year now. My inexperience in Linux. I have my development server running
ubuntu and the packages are available to load the latest Mapserver. For
this server (RHEL5 x86_64), I have not been able load Mapserver with
packages and thus my problems. This is my first experience compiling from
source and it has been quite and experience.
I ended up compiling geos, gdal and mapserver. I'm not sure all went
correctly but with some links added and removing some packages and loading
some packages I got the compile process to run.
I'm not sure what LD_LIBRARY_PATH is but I think that I did something
similar to what you suggested at some point.
Mapscript does load now and my application will run on this server now. I
suppose that if there is a problem with the compiling and installing, my
application will crash at some point.
Thanks again,
Worth
-----Original Message-----
From: daryl herzmann [mailto:akrherz at iastate.edu]
Sent: Sunday, July 04, 2010 12:39 PM
To: Worth Lutz
Cc: 'MAPSERVER-USERS'
Subject: Re: [mapserver-users] problem installing mapscript
Hello Worth,
Welcome to Mapserver!
On Sat, 3 Jul 2010, Worth Lutz wrote:
> This is my first time trying to install mapserver without using a package.
> I have not found a RPM for mapserver 5.6.3 for RHEL5
> I downloaded mapserver and did the configure and make. After installing
all
> the missing libs I thought I had it done.
> After copying moving php_mapscript.so to the proper location, I find that
> upon restarting apache it does not load. Here is the message from the
error
> log.
> ---snip-------
> PHP Warning: PHP Startup: Unable to load dynamic library
> '/usr/lib64/php/modules/php_mapscript.so' - libgeos-3.2.0.so: cannot open
> shared object file: No such file or directory in Unknown on line 0
> ---snip-------
This is a sign that the location you put libgeos-3.2.0.so is not in the
system's nor apache's LD_LIBRARY_PATH. If libgeos is in /usr/local/lib,
make sure that is in either /etc/ld.so.conf or in a file in
/etc/ld.so.conf.d/ . Typically, I do this.
echo "/usr/local/lib" >> /etc/ld.so.conf.d/usrlocal.conf
ldconfig
> In an effort to correct this, I downloaded and installed libgeos and
> tried to install it. I also tried to install a rpm with libgeos 3.1.1.
If you did this after compiling geos and mapserver, you probably have a
conflict going now.
> /usr/bin/ld: warning: libpq.so.4, needed by /usr/lib64/libgdal.so, may
> conflict with libpq.so.5
Did you compile gdal or get it from a third party packager?
daryl
