[mapserver-users] adding a palette to a greytiff
michele pierri
pierm4ci at yahoo.it
Wed Jul 7 17:20:41 EDT 2010
I have added this line in .map file:CONFIG "MS_ERRORFILE" "/tmp/mapserver.log"
And this is the output:
[Wed Jul 7 23:18:21 2010].797918 CGI Request 1 on process 4712[Wed Jul 7 23:18:21 2010].798507 msDrawMap(): Drawing Label Cache, 0.000s[Wed Jul 7 23:18:21 2010].798536 msDrawMap() total time: 0.000s[Wed Jul 7 23:18:21 2010].805594 msSaveImage() total time: 0.007s[Wed Jul 7 23:18:21 2010].805715 mapserv request processing time (loadmap not incl.): 0.008s[Wed Jul 7 23:18:21 2010].805731 msFreeMap(): freeing map at 0x8dd72a0.
May be useful?
Thanks.
--- Mer 7/7/10, michele pierri <pierm4ci at yahoo.it> ha scritto:
Da: michele pierri <pierm4ci at yahoo.it>
Oggetto: Re: [mapserver-users] adding a palette to a greytiff
A: "Alexander Petkov" <greenkov at gmail.com>, mapserver-users at lists.osgeo.org
Data: Mercoledì 7 luglio 2010, 22:58
How I have to set EXTENT parameter? What are the correct value?
Can you take me an example?
Thanks a lot.Michele.
--- Mer 7/7/10, Alexander Petkov <greenkov at gmail.com> ha scritto:
Da: Alexander Petkov <greenkov at gmail.com>
A: "michele pierri" <pierm4ci at yahoo.it>
Cc: mapserver-users at lists.osgeo.org
Data: Mercoledì 7 luglio 2010, 22:52
The first thing that I see is that the EXTENT needs to be corrected in your map file.
On Wed, Jul 7, 2010 at 2:47 PM, michele pierri <pierm4ci at yahoo.it> wrote:
This is what I request with a browser.http://localhost/cgi-bin/mapserv?map=/var/www/sviluppo/workshop-5.4/prova.map&mode=map
Thanks again,Michele.
Data: Mercoledì 7 luglio 2010, 22:28
Can you also include a sample request that gives you a blank map?
On Wed, Jul 7, 2010 at 1:57 PM, michele pierri <pierm4ci at yahoo.it> wrote:
Hi, thanks for help me.
1. Is your file indeed georeferenced?
Yes it is georeferenced.
2. The style definitions look good, the only thing I see missing are
the class names. Not sure if that matters if you don't display a
legend.How I have to modify the .map file for add this information? Can you write me an example?
3. Have you got the map file working without the class definitions?
I.E get a grayscale map?
If I write this file map I have always blank image:
MAP NAME "prova"
CONFIG "PROJ_LIB" "/usr/share/proj/" STATUS ON SHAPEPATH "./" SIZE 494 531
PROJECTION "init=epsg:4326" END EXTENT -154 -57 26 33 DEBUG 5
WEB IMAGEPATH
"/var/www/sviluppo//workshop-5.4/tmp/" IMAGEURL "/sviluppo/tmp/" END
LAYER
NAME "tif" DATA "prova.tif" STATUS ON TYPE RASTER OFFSITE 0 0 0
ENDEND
4. Have you attempted to discover what is wrong by looking at the
mapserver log? You will
need to enable logging in your map file.How I can enable it?
I have upload the image on another upload web service:http://www.megaupload.com/?d=K8SY5IP3
you can try this if you want.Or can you try with a your image?
Thanks again.Michele.
2010, 21:29
For some reason I can;t get to the file you posted, so I have a few question.
legend.
mapserver log? You will need to enable logging in your map file.
Alex
On Wed, Jul 7, 2010 at 9:44 AM, michele pierri <pierm4ci at yahoo.it> wrote:
> Hi,
> I have this image: http://www.2shared.com/photo/Qu2cyRc2/prova.html
> I would visualize it with a colour scaled
palette.
> I have write this file.map, but I receive only blank page.
> MAP
> NAME "prova"
> STATUS ON
> SHAPEPATH "./"
> SIZE 494 531
> PROJECTION
> "init=epsg:4326"
> END
> DEBUG 5
> WEB
> IMAGEPATH "/var/www/sviluppo//workshop-5.4/tmp/"
> END
> LAYER
> NAME
"tif"
> DATA "prova.tif"
> STATUS ON
> TYPE RASTER
> OFFSITE 0 0 0
> CLASSITEM "[pixel]"
> CLASS
> EXPRESSION ([pixel] >= 0 AND [pixel] < 10 )
> STYLE
> COLOR 0 255 255
> END
> END
> CLASS
> EXPRESSION ([pixel] >= 10 AND [pixel] < 40)
STYLE
> COLOR 0 255 0
> END
> END
> CLASS
> EXPRESSION ( [pixel] >= 40 AND [pixel] < 80)
> STYLE
> COLOR 255 255 0
> END
> END
> CLASS
> EXPRESSION ([pixel] >= 80 AND [pixel] < 120)
> STYLE
COLOR 255 127 0
> END
> END
> CLASS
> EXPRESSION ([pixel] >= 120 AND [pixel] < 150)
> STYLE
> COLOR 255 0 0
> END
> END
> CLASS
> EXPRESSION ([pixel] >= 150 AND [pixel] < 200)
> STYLE
> COLOR 255 127 255
END
> END
> CLASS
> EXPRESSION ([pixel] >= 200 AND [pixel]<40)
> STYLE
> COLOR 0 0 0
> END
> END
> END
> END
> Can anyone help me please? I am sorry but I am a beginner.
> Thanks in advance,
> Michele.
-----Segue allegato-----
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100707/05b1ea20/attachment.html
