[mapserver-users] Using Open street map tiles via GDAL_WMS
Brent Fraser
bfraser at geoanalytic.com
Fri Jul 9 15:40:29 EDT 2010
It took a little debugging (the ultimate documentation), but the answer is to add:
PROCESSING "OVERSAMPLE_RATIO=1" # the default is 2!
PROCESSING "LOAD_FULL_RES_IMAGE=NO"
to the layer in map file.
Best Regards,
Brent Fraser
Brent Fraser wrote:
> James,
> Did you find a solution to this problem? I'd like to use OSM tiles in
> Mapscript to create an image for server-side creation of large format
> PDFs for printing, and found that mapserver+GDAL does not calculate the
> best TileLevel based on the output extents and image size.
> For example, in my XML file I have:
> <TileLevel>15</TileLevel>
> When using gdal_translate:
> gdal_translate -projwin -12412016 7714617 -12384098 7693893 -outsize
> 1461 1084 frmt_wms_osm_tms.xml test.tif
> GDAL requests Level 13 images, and produces a great looking image.
> However Mapserver's shp2img:
> shp2img -e -12412016 7693893 -12384098 7714617 -s 1461 1084 OSM.map -o
> requests Level 14 (too high a resolution); many more tiles are requested
> and down-sampled, and the image is un-readable.
> Best Regards,
> Brent Fraser
> James Perrins wrote:
>> I've been trying to use Open street map tiles via a mapserver WMS
>> service displayed in OpenLayers.
>> This is sort of working - in that I'm getting maps displayed and they
>> seem to be in the right position (as checked against other datasets).
>> My issue is that the images are nowhere near as clear as the originals
>> from the Open Street map tiles. I've kept projections the same
>> throughout - and they don't appear to be being re-projected. The
>> images saved in the local cache (if enabled) are the same as from Open
>> Street Map. What appears to be happening is that mapserver is getting
>> images from (perhaps) a zoom level too high - and then re-sampling
>> these to produce the WMS output image - which then appears to have too
>> much detail displayed for its zoom level (if you understand what I'm
>> trying to say).
>> Any ideas why this is happening - I've messed around with Bounding
>> boxes and image sizes - but it doesn't seem to make any difference.
>> Thanks
>> James
>> MapFile extract:
>> LAYER
>> NAME "OSM"
>> STATUS ON
>> TYPE RASTER
>> DATA "D:\Websites\OpenStreetMap\OSM.xml"
>> PROJECTION
>> "init=EPSG:900913"
>> END
>> END
>> <GDAL_WMS>
>> <Service name="TMS">
>> <ServerUrl>http://tile.openstreetmap.org/${z}/${x}/${y}.png</ServerUrl>
>> </Service>
>> <DataWindow>
>> <UpperLeftX>-20037508.34</UpperLeftX>
>> <UpperLeftY>20037508.34</UpperLeftY>
>> <LowerRightX>20037508.34</LowerRightX>
>> <LowerRightY>-20037508.34</LowerRightY>
>> <TileLevel>19</TileLevel>
>> <TileCountX>1</TileCountX>
>> <TileCountY>1</TileCountY>
>> <YOrigin>top</YOrigin>
>> </DataWindow>
>> <Projection>EPSG:900913</Projection>
>> <BlockSizeX>256</BlockSizeX>
>> <BlockSizeY>256</BlockSizeY>
>> <BandsCount>3</BandsCount>
>> </GDAL_WMS>
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
