[mapserver-users] getlegendgraphic error with GROUP layers
Stephan Holl
stephan.holl at intevation.de
Mon Jul 12 02:20:14 EDT 2010
Hello Todd,
"Todd Harris" <Todd.Harris at landgate.wa.gov.au>, [20100712 - 12:54:58]
> Hi all, I'm hoping someone can help.
> I'm getting this error when requesting getlegendgraphic with GROUP
> layers (MapServer-5.2.3):
> ServiceException code="LayerNotDefined">msWMSGetLegendGraphic(): WMS
> server error. Invalid layer given in the LAYER
> parameter.</ServiceException>
AFAIK this is not implemented yet. See [1].
@Assefa: Do you have a more detailed implementation plan for this
issue? I am also highly interested in this feature.
Best regards
Stephan
[1] http://trac.osgeo.org/mapserver/ticket/3411
> I cannot find a solution - can someone please help?
> Kind regards
> Todd
> This e-mail and any files transmitted with it are intended only for
> the use of the addressee(s). It may contain information that is
> confidential and privileged, in which case neither is intended to be
> waived or lost by mistaken delivery to you. If you are not an
> intended recipient, any use, interference with, disclosure,
> distribution or copying of this material is unauthorised and
> prohibited. If you receive this e-mail in error, please notify the
> sender by return e-mail and delete the message and any attachments
> from your system. Unless specifically indicated, this e-mail does not
> constitute formal advice or commitment by the sender or the Western
> Australian Land Information Authority (Landgate). Information in this
> message not relating to the official business of Landgate shall be
> understood as neither given nor endorsed by it. It is your
> responsibility to check any attachments for viruses and defects
> before opening or sending them on. Landgate’s liability is limited to
> re-supplying affected attachments.
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100712/3e942162/signature.bin
