[mapserver-users] Windows 2008; Java; 64 Bit
Tamas Szekeres
szekerest at gmail.com
Tue Jul 13 10:43:53 EDT 2010
Benedikt,
It may be a bug in the mapscript Java bindings, feel free to create a
ticket<http://trac.osgeo.org/mapserver/newticket>for this issue.
Best regards,
Tamas
2010/7/13 <umn-ms at hydrotec.de>
> I want to use Mapserver in TomCat6; Windows 2008; 64 Bit; Sun-Java 1.6..21
> Mapserver compiled by Tamas Szekeres:
> release-1500-x64-gdal-1-7-mapserver-5-6.zip (*
> vbkto.dyndns.org/sdk/Default.aspx*<http://vbkto.dyndns.org/sdk/Default.aspx>
> Unfortunately the Java-VM crashes!
> To reduce the problem I tried example-programs in
> <UMN>\mapscript\java\examples\
> - MakePoint runs without error.
> - QueryByAttribute results in the same crash as the
> "big-tomcat-environment" does.
> As far as I can see, the crash occurs every time, when a string-parameter
> ist provided to the Mapserver API.
> I think, that the VM-crash occurs, when the function
> "JNU_GetStringNativeChars(jenv, jarg1)" from mapscript_wrap.c
> is called.
> Surprinsingly the error occurs with other release-XXX-packages from Tamas
> too.
> It even occurs, when I use a 32-Bit-Environment an MS4w on this computer.
> I attach an hs_err_pid-xxxx.log-File.
> Does anybody has any advice?
> Greetings, Benedikt
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100713/4ae14238/attachment.html
