[mapserver-users] Windows 2008; Java; 64 Bit
umn-ms at hydrotec.de
Tue Jul 13 12:26:08 EDT 2010
Hi Tamas
I created trac.osgeo.org/mapserver/ticket/3491.
In hope of advise I was bold enough to put your email-adress in cc :-)
Best regards , Benedikt
Tamas Szekeres <szekerest at gmail.com> schrieb am 13.07.2010 16:43:53:
> 13.07.2010 16:52
> An
> Kopie
> mapserver-users at lists.osgeo.org
> Thema
> Re: [mapserver-users] Windows 2008; Java; 64 Bit
> Benedikt,
> It may be a bug in the mapscript Java bindings, feel free to create a
ticket
> for this issue.
> Best regards,
> Tamas
> 2010/7/13 <umn-ms at hydrotec.de>
> I want to use Mapserver in TomCat6; Windows 2008; 64 Bit; Sun-Java
1.6..21
> Mapserver compiled by Tamas Szekeres: release-1500-x64-gdal-1-7-
> mapserver-5-6.zip (vbkto.dyndns.org/sdk/Default.aspx )
> Unfortunately the Java-VM crashes!
> To reduce the problem I tried example-programs in <UMN>\mapscript
> \java\examples\
> - MakePoint runs without error.
> - QueryByAttribute results in the same crash as the "big-tomcat-
> environment" does.
> As far as I can see, the crash occurs every time, when a string-
> parameter ist provided to the Mapserver API.
> I think, that the VM-crash occurs, when the function
> "JNU_GetStringNativeChars(jenv, jarg1)" from mapscript_wrap.c
> is called.
> Surprinsingly the error occurs with other release-XXX-packages
fromTamas too.
> It even occurs, when I use a 32-Bit-Environment an MS4w on this
computer.
> I attach an hs_err_pid-xxxx.log-File.
> Does anybody has any advice?
> Greetings, Benedikt
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100713/336b5971/attachment.html
