[mapserver-users] MAXSCALEDENOM [scale_field]
Daniel Degasperi
daniel.degasperi at r3-gis.com
Thu Jul 15 06:02:22 EDT 2010
Hi Steve,
maybe it's easier to explain with a mapfile example:
LAYER
NAME "POI"
TYPE POINT
CONNECTIONTYPE postgis
CONNECTION "user=somebody password=something dbname=test
host=localhost"
DATA "the_geom FROM (SELECT gid, category, priority, the_geom FROM
poi) AS foo USING UNIQUE gid"
CLASS
EXPRESSION ('[category]' eq 'poi')
MAXSCALEDENOM [priority]
END
END
In this case I've one single class for each category and the
MAXSCALEDENOM get the value from the priority attribute of my datasource.
As it is now, MapServer does not support this feature and I've to repeat
every single category for each different priority value.
Best regards,
Daniel
Am 14/07/2010 23:53, schrieb Lime, Steve D (DNR):
> MapServer doesn't support layer-level binding only feature-level binding. I'm having trouble seeing the value. Can you explain further?
> Steve
> ________________________________________
> From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Daniel Degasperi [daniel.degasperi at r3-gis.com]
> Sent: Wednesday, July 14, 2010 7:54 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] MAXSCALEDENOM [scale_field]
> Hi,
> I've tried to read the MAXSCALEDENOM value from a attribute in my
> datasource, but mapserver throw's a parsing error.
> Probably because such feature does not exist in mapserver.
> Are there any intentions to implement this?
> It could be interesting for layers, whose data has different priorities
> but the same styling.
> With this feature I can avoid repeating the classes for every priority.
> Best regards,
> Daniel
