[mapserver-users] PostGIS Layer : get only objects WITHIN view
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Fri Jul 16 12:39:48 EDT 2010
Nope, that's the issue, there's no magic variable for the map extent nor is there a processing option. I suspect this would be lightly used (since it's never been asked for before). Runtime subs may be your best option. Depends on how accurate your extent is when it's passed, that is, does MapServer have to adjust it. You could probably hack this easily, pass the hack along so it gets to 6.0.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Guillaume Sueur
Sent: Thursday, July 15, 2010 6:31 PM
To: Mapserver-users
Subject: Re: [mapserver-users] PostGIS Layer : get only objects WITHIN view
Hi Steve,
Ok for the CONTAINS thing, but what is supposed to contain my geom field
? Is there a magic variable like %MAP_EXTENT% usable in the mapfile ?
Regards
Guillaume
Le 15/07/2010 21:40, Lime, Steve D (DNR) a écrit :
> I'd think you'd need to use one of the spatial operators like "contains" in your data statement. However, you'd need access to the computed map extent to be able to do so. There's another thread related to this topic but with the computed scale.
> Steve
> Sent: Thursday, July 15, 2010 9:48 AM
> To: Mapserver-users
> Subject: [mapserver-users] PostGIS Layer : get only objects WITHIN view
> Hi list,
> I was wondering if there was an efficient way to display only objects
> fully included inside the map viewport. I could mess around with runtime
> substitution, but as bbox is already sent, I think there is a way to use
> it inside my DATA string.
> Thanks for your clues
> Guillaume
> mapserver-users at lists.osgeo.org
