[mapserver-users] PostGIS Layer : get only objects WITHIN view
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jul 20 20:46:20 EDT 2010
Maybe something like this would work for you:
http://trac.osgeo.org/mapserver/ticket/2129
I did this a few years ago for a client but it was between Oracle
developers and never got put in the trunk code. I don't work with an
Oracle instance at the moment but there is a patch and you might be able
to adapt it to your needs.
-Steve W
Lime, Steve D (DNR) wrote:
> Nope, that's the issue, there's no magic variable for the map extent
> nor is there a processing option. I suspect this would be lightly
> used (since it's never been asked for before). Runtime subs may be
> your best option. Depends on how accurate your extent is when it's
> passed, that is, does MapServer have to adjust it. You could probably
> hack this easily, pass the hack along so it gets to 6.0.
> Steve
> -----Original Message----- From:
> mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
> Guillaume Sueur Sent: Thursday, July 15, 2010 6:31 PM To:
> Mapserver-users Subject: Re: [mapserver-users] PostGIS Layer : get
> Hi Steve,
> Ok for the CONTAINS thing, but what is supposed to contain my geom
> field ? Is there a magic variable like %MAP_EXTENT% usable in the
> mapfile ?
> Regards
> Guillaume
> Le 15/07/2010 21:40, Lime, Steve D (DNR) a écrit :
>> I'd think you'd need to use one of the spatial operators like
>> "contains" in your data statement. However, you'd need access to
>> the computed map extent to be able to do so. There's another thread
>> related to this topic but with the computed scale.
>> Steve
>> Guillaume Sueur Sent: Thursday, July 15, 2010 9:48 AM To:
>> Mapserver-users Subject: [mapserver-users] PostGIS Layer : get only
>> objects WITHIN view
>> Hi list,
>> I was wondering if there was an efficient way to display only
>> objects fully included inside the map viewport. I could mess around
>> with runtime substitution, but as bbox is already sent, I think
>> there is a way to use it inside my DATA string.
>> Thanks for your clues
>> Guillaume _______________________________________________
>> mapserver-users mailing list mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> _______________________________________________ mapserver-users
