[mapserver-users] Re: Styling a mapfile with SLD?
Yewondwossen Assefa
yassefa at dmsolutions.ca
Wed Jun 2 09:24:09 EDT 2010
On 02/06/2010 9:01 AM, Rahkonen Jukka wrote:
> Yewondwossen Assefa wrote:
>> On 02/06/2010 2:39 AM, paalkr wrote:
>>> Hi!
>>> Thanks! I really don't understand how that poorly formatted
>> SLD slipped
>>> trough the oxygen XML editor, obviously there are many
>> close-tags that
>>> misses the backslash.
>>> Do you know if there is a ticket regarding the lack of
>> error messages when
>>> MapServer fails to either pick up or parse a SLD document?
>> If not I think
>>> that I will write one, and encourage one of my colleagues
>> to have a look at
>>> the source and maybe write a patch for it.
>> There is an ol one
>> http://trac.osgeo.org/mapserver/ticket/1471 that I
>> just updated. The errors are trapped but at this point we let the WMS
>> request succeed without the SLD. I believe the correct way
>> would be to
>> return an exception.
> This needs some consideration. Think about an end user who is using
> somew ready made application which is set to get styles from an external
> SLD. Now if this SLD gets broken, which would you prefer as an user: a
> correct exception without a map, or a map which may have wrong styling?
> I would take the map.
> -Jukka Rahkonen-
I guess it is debatable. I have not seen something in the specs re. this
issue. I will send a note to wms-dev list at OGC to see if there is
something in the specs that deals with this issue.
best regards,
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
