[mapserver-users] about thematics maps
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue Jun 8 12:35:59 EDT 2010
Not necessarily. By layer I'm guessing you mean data source? If so you can certainly have multiple MapServer
layers that reference the same data source but style the data differently. You can also have a single MapServer
layer that can be configured dynamically to style the data differently. For example, you might have a constant
thematic presentation based on a percentage value (e.g. 0->10: green, 10-20:yellow, etc...) and then you use
different attributes (e.g. % income above $50,000, % age > 60, % residents with yellow beagles) against that
classification. All sorts of possibilities depending on your data.
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of salas
Sent: Tuesday, June 08, 2010 12:13 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] about thematics maps
Hi, i need obtain various thematic maps , using the same layer.
For this work i have to use different map(.map) file?
bets regards Salas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100608/1705f321/attachment.html
