[mapserver-users] rasterquery
Sven Schroeter
schroeter at netgis.de
Wed Jun 9 08:27:27 EDT 2010
I try to make a raster query using phpmapscript
My layer in the mapfile:
# DHM ESRI Grid
LAYER
NAME "mydhm"
DATA "dhm_vg/grid/dhm_vg" #grid dir
STATUS default
TYPE RASTER
TEMPLATE "template/query.html"
END
My php code:
//load mapfile
$map= ms_newMapObj($mapfilepath.'\map.map');
//create point
$qPoint = ms_newPointObj();
$qPoint->setXY(2554032,5521435);
//set layer
$layer = $map->getLayerByName("mydhm");
//query
@$datQuery = $layer->queryByPoint($qPoint, MS_SINGLE, 1);
if ($datQuery == MS_SUCCESS) {
echo "OK!";
this works fine with mapserver 5.02 but there is no result with mapserver
5.6.1
apServer version 5.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
Any idea?
Sven
