[mapserver-users] Problem with postgis querybypoint in mapserver-php (abusqu***)
Guillermo Tamburini Beliveau
guitambe at topo.upv.es
Fri Jun 11 03:33:47 PDT 2010
At last I forgot to put the user name.
thank you.
Mensaje citado por Guillermo Tamburini Beliveau <guitambe at topo.upv.es>:
> Hi,
> I'm trying to recover the line of an ancient subject that I wrote to the
> list!
> It is about a problem with the querybypoint method in php in mapserver with
> postgis layers. If you want to see it, please take a look below (previous
> message).
> I unsubscribed the list because my main reason was to get a response to my
> doubt, and nobody response me. But now, browsing the net, I've seen that a
> user
> responded!
> Please if you have more information about my problem, reply me because I
> haven't
> resolved it yet.
> And please, excuse me for using your user name in the subject, I couldn't
> send
> you an e-mail.
> Previous message -----------------------------------------------------------
> Hi,
> I would like to know if some body knows the reason of a strange problem that
> I'm
> having with the php-mapscript methods for the query methods in the postgis
> layers.
> Indistinctly for querybypoint or querbyrectangle, my code (different versions
> of
> it), works perfectly with shapes, but it always fails with the postgis
> layers.
> When calling to the shapeindex member of the ResultCacheMemberObj obtained,
> it
> always returns 0, as is contrary to what happends with the shapes, where it
> always returns the correct shapeindex.
> Then it is impossible to acces to the desidered feature.
> May I have to add more columns to the select of the .map file for getting
> the
> features atributes like in the example (I don't think so)?
> DATA "geom FROM puntos using unique gid"
> # DATA "geom FROM (select gid , nombre, tramo, geom from puntos) as
> foo
> using
> unique geom"
> # DATA "geom FROM (select * from puntos) as foo using unique gid"
> Or there is some paramter in the configuration files of mapserver or php
> that I
> have to change.
> There is the code of the function:
> function CercaPunto($point,$map,$radius) {
> $qlayer = $map->getLayerByName('trazado');
> $qlayer->set("tolerance",$radius);
> @$qlayer->queryByPoint($point, MS_MULTIPLE, $radius);
> $numResults = $qlayer->getNumResults();
> if ($numResults != 0) {
> for ($i = 0; $i < $numResults; $i++) {
> $query_result = $qlayer->getResult($i);
> $Lista_ele[$i] = $query_result->shapeindex; // Here is the
> error
> with postgres
> } else {
> $valido =0;
> $Lista_ele = "";
> return $Lista_ele;
> } // end CercaPunto
> Thank you very much.
> mapserver-users at lists.osgeo.org
----- Fin del mensaje reenviado -----
More information about the MapServer-users
