[mapserver-users] Query data in tileindex problem
Paul Ramsey
pramsey at cleverelephant.ca
Tue Jun 22 18:53:03 EDT 2010
Perhaps there's an actual fix someone else knows about, I have only a comment:
* If you were using tileindexes as a performance boost, you can move
to a single unified shapefile, since the performance issues that used
to require tileindexes as a workaround were removed in 5.4.
Best,
P
On Tue, Jun 22, 2010 at 3:46 PM, Eric Weisbender <Weisbend at wapa.gov> wrote:
> I'm drawing county parcel data using a tileindex layer definition that
> points to the parcel polys. When I Query a parcel I get the following
> error. Failed to draw layer named 'parcel' msDBFReadAttribute(): DBASE file
> error. Invalid field index 0. We just upgraded to Mapserver 5.6.3 from 4.10
> where it was working fine. Any help or ideas would be greatly appreciated.
> Thanks,
> EW
> mapserver-users at lists.osgeo.org
