[mapserver-users] Re: OSM renderer with MapServer
(christopher.schmidt@nokia.com)
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Jun 28 09:40:06 EDT 2010
The Windows version of osm2pgsql does not find automatically proj4 libraries which are needed for doing import with -l switch or with -E switch. For making these switches to work user should install proj4 in some way and set an environment variable to point to that location. Too tricky, so I would suggest Windows users to import with the default projection 900913. The data can be rather fast reprojected afterwards inside PostGIS, if needed.
Windows is also lacking the preprocessor that is needed to build up the final mapfile if user is following the cookbook by Thomas. Perhaps there could be also a ready compiled mapfile available for Windows users for a quicker start?
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: thomas bonfort
Lähetetty: ma 28.6.2010 16:24
Vastaanottaja: Kent Morrison
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] Re: OSM renderer with MapServer (christopher.schmidt at nokia.com)
The document needs to be updated. You should either update the
mapfiles and change "using srid=4326" to "using srid=900913", or
reimport the osm data in lonlat format (osm2pgsql -l switch).
regards,
thomas
On Mon, Jun 28, 2010 at 15:18, Kent Morrison <KMorrison at advantrack.com> wrote:
> I tried to get OSM running on MapServer using the instructions linked below and was only partially successful. It would render the coastlines but nothing else and there was no error messages in the debug file.
> Kent
> Message: 3
> Date: Fri, 25 Jun 2010 20:25:19 +0200
> From: "christopher.schmidt at nokia.com" <christopher.schmidt at nokia.com>
> Subject: Re: [mapserver-users] OSM renderer with MapServer
> To: <bfischer at houstoneng.com>
> Cc: mapserver-users at lists.osgeo.org
> Message-ID: <058B56D2-801E-4CDF-AF06-506432DFDD66 at nokia.com>
> Content-Type: text/plain; charset="Windows-1252"
> On Jun 25, 2010, at 1:52 PM, ext Brian Fischer wrote:
>> Is there anyone working on a MapServer mapfile(s) to renderer OpenStreetMap data in the U.S.? I?m interested in creating a mapfile that displays nice cartographic map for the roads and uses highway shields for the labels. Ultimately turning this into a TMS using tilecache. Or would people recommend sticking with Mapnik?s stylesheets to render the data into images? I did a few searches and only came across this. http://code.google.com/p/mapserver-utils/source/browse/trunk I?m new to OSM data so just starting to explore options.
> http://trac.osgeo.org/mapserver/wiki/RenderingOsmData leads to that location as well; This is the mapfile that is used for the map on the homepage:
> http://mapserver.org/
> So it's probably a safe starting point.
> Regards,
> Christopher Schmidt
> Nokia
> End of mapserver-users Digest, Vol 29, Issue 43
