[mapserver-users] getmap request with SLD failing after upgrade to
5.6.0
DeDuikertjes
DeDuikertjes at xs4all.nl
Tue Mar 2 14:21:46 EST 2010
Hi List,
Finally I managed to upgrade mapserver 5.1-dev (FWTools) to 5.6.0 (FGS).
I use it as a WMS. Everything looks fine, but I've one anoying problem:
When I do a getmap-request with an SLD I get an empty image back, while
5.1-dev gives me a proper result.
Other getmap requests work fine.
I tested this several times by swapping the old mapserv executable with
the new one.
an example of a getmap request which fails on 5.6.0 and succeeds in
5.1-dev is:
https://85.12.17.114/cgi-bin/mapserv?map=../html/viewerfabriek-alpha/data/vf_80.101.100.35_check/4b8d40f7e0787/NL.IMRO.0184.Zeewijkfase4-0201.map&LAYERS=query&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SLD_BODY=%3C%3Fxml%20version%3D%221.0%22%20encoding%3D%22utf-8%22%3F%3E%3Csld%3AStyledLayerDescriptor%20version%3D%221.0.0%22%3E%3Csld%3ANamedLayer%3E%3Csld%3AName%3Equery%3C%2Fsld%3AName%3E%3Csld%3AUserStyle%3E%3Csld%3AName%3Equery%3C%2Fsld%3AName%3E%3Csld%3AFeatureTypeStyle%3E%3Csld%3ARule%3E%3Cogc%3AFilter%3E%3Cogc%3APropertyIsEqualTo%3E%3Cogc%3APropertyName%3Egeoidn%3C%2Fogc%3APropertyName%3E%3Cogc%3ALiteral%3ENL.IMRO.0184.EP127818521-00%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3APropertyIsEqualTo%3E%3C%2Fogc%3AFilter%3E%3Csld%3APolygonSymbolizer%3E%3Csld%3AFill%3E%3Csld%3ACssParameter%20name%3D%22fill%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22fill-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3
E%3C%2Fsld%3AFill%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3APolygonSymbolizer%3E%3Csld%3ALineSymbolizer%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3ALineSymbolizer%3E%3C%2Fsld%3ARule%3E%3C%2Fsld%3AFeatureTypeStyle%3E%3C%2Fsld%3AUserStyle%3E%3C%2Fsld%3ANamedLayer%3E%3C%2Fsld%3AStyledLayerDescriptor%3E&SRS=EPSG%3A900913&BBOX=625312.21905694,6921632.3781404,627462.0104771,6922637.4056294&WIDTH=1800&HEIGHT=841
any help greatly appreciated, MArco
