[mapserver-users] getmap request with SLD failing after upgrade
to 5.6.0
Bart van den Eijnden
bartvde at osgis.nl
Wed Mar 3 03:01:04 EST 2010
It seems Mapserver does not treat your column as a character column, try using the following METADATA on your source layer (so not in the temporary MAP file):
"gml_geoidn_type" "Character"
Best regards,
Bart
On Mar 3, 2010, at 8:52 AM, DeDuikertjes wrote:
> Bart,
> Thanks for the suggestion. I've opened up the temporary MAP file. A layer definition from this file is (there are a LOT more like that):
> LAYER
> CONNECTION "host=xxxxxxx user=xxxxx dbname=xxxxxxx"
> CONNECTIONTYPE POSTGIS
> DATA 'tc_punt_geometry from "NL.IMRO.0184.Zeewijkfase4-0201_aggregated" using unique oid using srid=28992'
> DUMP TRUE
> GROUP "query"
> METADATA
> "wms_srs" "EPSG:28992 EPSG:900913 EPSG:4326"
> "ows_feature_id" "geoidn"
> "ows_group_title" "query"
> "ows_extent" "170861.5122 520007.0618 171570.1698 520546.6582"
> "gml_exclude_items" "tc_multi_geometry,tc_vlak_geometry,tc_lijn_geometry,tc_punt_geometry"
> "ows_title" "query_punt"
> "gml_include_items" "all"
> "ows_exclude_items" "all"
> END
> NAME "query_punt"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> PROJECTION
> "init=epsg:28992"
> END
> STATUS ON
> TEMPLATE "query.html"
> TYPE POLYGON
> UNITS METERS
> CLASS
> NAME "Unknown"
> EXPRESSION ([geoidn] = NL.IMRO.0184.EP127818521-00)
> STYLE
> ANGLE 360
> COLOR 255 0 255
> OPACITY 40
> SIZE 2
> SYMBOL "sld_line_symbol"
> WIDTH 1
> END
> STYLE
> ANGLE 360
> COLOR 255 0 255
> OPACITY 40
> SYMBOL 0
> WIDTH 1
> END
> STYLE
> ANGLE 360
> OPACITY 40
> OUTLINECOLOR 255 0 255
> SIZE 2
> WIDTH 1
> END
> END
> END
> MArco
> Bart van den Eijnden schreef:
>> Hi Marco,
>> Mapserver has saved a temporary MAP file, please open it up and check if something is wrong in there, or post the LAYER definition to the mailing list.
>>> /var/www/cgi-bin/../html/viewerfabriek-alpha/data/vf_80.101.100.35_check/4b8d40f7e0787/4b8e0df9_52ef_0._sld.map
>> Best regards,
>> Bart
>> On Mar 3, 2010, at 8:30 AM, DeDuikertjes wrote:
>>> Thank you,
>>> I've did as you said, but can't get a clue on what's going on.
>>> The error file shows:
>>> [Wed Mar 3 08:21:29 2010].677158 msApplySLD(): Map file after SLD was applied /var/www/cgi-bin/../html/viewerfabriek-alpha/data/vf_80.101.100.35_check/4b8d40f7e0787/4b8e0df9_52ef_0._sld.map[Wed Mar 3 08:21:29 2010].731599 msyyparse(): Expression parser error. syntax error
>>> [Wed Mar 3 08:21:29 2010].731628 msEvalExpression: Expression parser error. Failed to parse expression: NL.IMRO.0184.BA127909736-00 = NL.IMRO.0184.EP127818521-00
>>> [Wed Mar 3 08:21:29 2010].731649 msyyparse(): Expression parser error. syntax error
>>> And a lot more of these expression errors.
>>> Then followed by
>>> [Wed Mar 3 08:21:29 2010].745454 msDrawMap(): Layer 0 (query_vlak), 0.029s
>>> [Wed Mar 3 08:21:29 2010].747286 msDrawMap(): Layer 1 (query_lijn), 0.002s
>>> [Wed Mar 3 08:21:29 2010].749832 msDrawMap(): Layer 2 (query_punt), 0.003s
>>> [Wed Mar 3 08:21:29 2010].750760 msDrawMap(): Drawing Label Cache, 0.000s
>>> [Wed Mar 3 08:21:29 2010].750771 msDrawMap() total time: 0.046s
>>> [Wed Mar 3 08:21:29 2010].999507 msSaveImage() total time: 0.249s
>>> [Wed Mar 3 08:21:29 2010].999706 mapserv request processing time (msLoadMap not incl.): 0.336s
>>> [Wed Mar 3 08:21:29 2010].999723 msFreeMap(): freeing map at 0x81bf400.
>>> What is going wrong?
>>> MArco
>>> Yewondwossen Assefa schreef:
>>>> Hi There,
>>>> One way to debug would be to set your map file in debug, something like this:
>>>> CONFIG "MS_ERRORFILE" "f:/msapps/gmap-ms40/htdocs/gmap.log"
>>>> DEBUG 5
>>>> and check the logs. It should show you the map file after the sld has been applied. That might give a hint on what went wrong.
>>>> best regards,
>>>> DeDuikertjes wrote:
>>>>> Hi List,
>>>>> Finally I managed to upgrade mapserver 5.1-dev (FWTools) to 5.6.0 (FGS).
>>>>> I use it as a WMS. Everything looks fine, but I've one anoying problem:
>>>>> When I do a getmap-request with an SLD I get an empty image back, while
>>>>> 5.1-dev gives me a proper result.
>>>>> Other getmap requests work fine.
>>>>> I tested this several times by swapping the old mapserv executable with
>>>>> the new one.
>>>>> an example of a getmap request which fails on 5.6.0 and succeeds in
>>>>> 5.1-dev is:
>>>>> https://85.12.17.114/cgi-bin/mapserv?map=../html/viewerfabriek-alpha/data/vf_80.101.100.35_check/4b8d40f7e0787/NL.IMRO.0184.Zeewijkfase4-0201.map&LAYERS=query&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SLD_BODY=%3C%3Fxml%20version%3D%221.0%22%20encoding%3D%22utf-8%22%3F%3E%3Csld%3AStyledLayerDescriptor%20version%3D%221.0.0%22%3E%3Csld%3ANamedLayer%3E%3Csld%3AName%3Equery%3C%2Fsld%3AName%3E%3Csld%3AUserStyle%3E%3Csld%3AName%3Equery%3C%2Fsld%3AName%3E%3Csld%3AFeatureTypeStyle%3E%3Csld%3ARule%3E%3Cogc%3AFilter%3E%3Cogc%3APropertyIsEqualTo%3E%3Cogc%3APropertyName%3Egeoidn%3C%2Fogc%3APropertyName%3E%3Cogc%3ALiteral%3ENL.IMRO.0184.EP127818521-00%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3APropertyIsEqualTo%3E%3C%2Fogc%3AFilter%3E%3Csld%3APolygonSymbolizer%3E%3Csld%3AFill%3E%3Csld%3ACssParameter%20name%3D%22fill%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22fill-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3 E%3C%2Fsld%3AFill%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3APolygonSymbolizer%3E%3Csld%3ALineSymbolizer%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stroke%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParameter%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3ALineSymbolizer%3E%3C%2Fsld%3ARule%3E%3C%2Fsld%3AFeatureTypeStyle%3E%3C%2Fsld%3AUserStyle%3E%3C%2Fsld%3ANamedLayer%3E%3C%2Fsld%3AStyledLayerDescriptor%3E&SRS=EPSG%3A900913&BBOX=625312.21905694,6921632.3781404,627462.0104771,6922637.4056294&WIDTH=1800&HEIGHT=841
>>>>> any help greatly appreciated, MArco
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
