[mapserver-users] getmap request with SLD failing after upgrade
to 5.6.0
DeDuikertjes
DeDuikertjes at xs4all.nl
Wed Mar 3 03:40:11 EST 2010
I would love to, but mapserver makes these expressions from the SLD, not me.
MArco
Yves Jacolin schreef:
> Hi,
> I guees this is this part which run an error:
> error. Failed to parse expression: NL.IMRO.0184.BA127909736-00 =
> NL.IMRO.0184.EP127818521-00
> Try to change :
> EXPRESSION ([geoidn] = NL.IMRO.0184.EP127818521-00)
> in :
> EXPRESSION ([geoidn] = "NL.IMRO.0184.EP127818521-00")
> Regards,
> Y.
> Le mercredi 03 mars 2010 09:01:04, Bart van den Eijnden a écrit :
>> It seems Mapserver does not treat your column as a character column, try
>> using the following METADATA on your source layer (so not in the temporary
>> MAP file):
>> "gml_geoidn_type" "Character"
>> Best regards,
>> Bart
>> On Mar 3, 2010, at 8:52 AM, DeDuikertjes wrote:
>>> Bart,
>>> Thanks for the suggestion. I've opened up the temporary MAP file. A layer
>>> definition from this file is (there are a LOT more like that):
>>> LAYER
>>> CONNECTION "host=xxxxxxx user=xxxxx dbname=xxxxxxx"
>>> CONNECTIONTYPE POSTGIS
>>> DATA 'tc_punt_geometry from "NL.IMRO.0184.Zeewijkfase4-0201_aggregated"
>>> using unique oid using srid=28992' DUMP TRUE
>>> GROUP "query"
>>> METADATA
>>> "wms_srs" "EPSG:28992 EPSG:900913 EPSG:4326"
>>> "ows_feature_id" "geoidn"
>>> "ows_group_title" "query"
>>> "ows_extent" "170861.5122 520007.0618 171570.1698 520546.6582"
>>> "gml_exclude_items"
>>> "tc_multi_geometry,tc_vlak_geometry,tc_lijn_geometry,tc_punt_geometry"
>>> "ows_title" "query_punt"
>>> "gml_include_items" "all"
>>> "ows_exclude_items" "all"
>>> END
>>> NAME "query_punt"
>>> PROCESSING "CLOSE_CONNECTION=DEFER"
>>> PROJECTION
>>> "init=epsg:28992"
>>> END
>>> STATUS ON
>>> TEMPLATE "query.html"
>>> TYPE POLYGON
>>> UNITS METERS
>>> CLASS
>>> NAME "Unknown"
>>> STYLE
>>> ANGLE 360
>>> COLOR 255 0 255
>>> OPACITY 40
>>> SIZE 2
>>> SYMBOL "sld_line_symbol"
>>> WIDTH 1
>>> END
>>> STYLE
>>> ANGLE 360
>>> COLOR 255 0 255
>>> OPACITY 40
>>> SYMBOL 0
>>> WIDTH 1
>>> END
>>> STYLE
>>> ANGLE 360
>>> OPACITY 40
>>> OUTLINECOLOR 255 0 255
>>> SIZE 2
>>> WIDTH 1
>>> END
>>> END
>>> END
>>> MArco
>>> Bart van den Eijnden schreef:
>>>> Hi Marco,
>>>> Mapserver has saved a temporary MAP file, please open it up and check if
>>>> something is wrong in there, or post the LAYER definition to the
>>>> mailing list.
>>>>> /var/www/cgi-bin/../html/viewerfabriek-alpha/data/vf_80.101.100.35_chec
>>>>> k/4b8d40f7e0787/4b8e0df9_52ef_0._sld.map
>>>> Best regards,
>>>> Bart
>>>> On Mar 3, 2010, at 8:30 AM, DeDuikertjes wrote:
>>>>> Thank you,
>>>>> I've did as you said, but can't get a clue on what's going on.
>>>>> The error file shows:
>>>>> [Wed Mar 3 08:21:29 2010].677158 msApplySLD(): Map file after SLD was
>>>>> applied
>>>>> k/4b8d40f7e0787/4b8e0df9_52ef_0._sld.map[Wed Mar 3 08:21:29
>>>>> 2010].731599 msyyparse(): Expression parser error. syntax error [Wed
>>>>> Mar 3 08:21:29 2010].731628 msEvalExpression: Expression parser error.
>>>>> NL.IMRO.0184.EP127818521-00 [Wed Mar 3 08:21:29 2010].731649
>>>>> msyyparse(): Expression parser error. syntax error And a lot more of
>>>>> these expression errors.
>>>>> Then followed by
>>>>> [Wed Mar 3 08:21:29 2010].745454 msDrawMap(): Layer 0 (query_vlak),
>>>>> 0.029s [Wed Mar 3 08:21:29 2010].747286 msDrawMap(): Layer 1
>>>>> (query_lijn), 0.002s [Wed Mar 3 08:21:29 2010].749832 msDrawMap():
>>>>> Layer 2 (query_punt), 0.003s [Wed Mar 3 08:21:29 2010].750760
>>>>> msDrawMap(): Drawing Label Cache, 0.000s [Wed Mar 3 08:21:29
>>>>> 2010].750771 msDrawMap() total time: 0.046s [Wed Mar 3 08:21:29
>>>>> 2010].999507 msSaveImage() total time: 0.249s [Wed Mar 3 08:21:29
>>>>> 2010].999706 mapserv request processing time (msLoadMap not incl.):
>>>>> 0.336s [Wed Mar 3 08:21:29 2010].999723 msFreeMap(): freeing map at
>>>>> 0x81bf400.
>>>>> What is going wrong?
>>>>> MArco
>>>>> Yewondwossen Assefa schreef:
>>>>>> Hi There,
>>>>>> One way to debug would be to set your map file in debug, something
>>>>>> like this: CONFIG "MS_ERRORFILE"
>>>>>> "f:/msapps/gmap-ms40/htdocs/gmap.log"
>>>>>> DEBUG 5
>>>>>> and check the logs. It should show you the map file after the sld has
>>>>>> been applied. That might give a hint on what went wrong.
>>>>>> best regards,
>>>>>> DeDuikertjes wrote:
>>>>>>> Hi List,
>>>>>>> Finally I managed to upgrade mapserver 5.1-dev (FWTools) to 5.6.0
>>>>>>> (FGS). I use it as a WMS. Everything looks fine, but I've one anoying
>>>>>>> problem:
>>>>>>> When I do a getmap-request with an SLD I get an empty image back,
>>>>>>> while 5.1-dev gives me a proper result.
>>>>>>> Other getmap requests work fine.
>>>>>>> I tested this several times by swapping the old mapserv executable
>>>>>>> with the new one.
>>>>>>> an example of a getmap request which fails on 5.6.0 and succeeds in
>>>>>>> 5.1-dev is:
>>>>>>> https://85.12.17.114/cgi-bin/mapserv?map=../html/viewerfabriek-alpha/
>>>>>>> data/vf_80.101.100.35_check/4b8d40f7e0787/NL.IMRO.0184.Zeewijkfase4-02
>>>>>>> 01.map&LAYERS=query&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMa
>>>>>>> p&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SLD_BODY=%3C%3Fx
>>>>>>> ml%20version%3D%221.0%22%20encoding%3D%22utf-8%22%3F%3E%3Csld%3AStyled
>>>>>>> LayerDescriptor%20version%3D%221.0.0%22%3E%3Csld%3ANamedLayer%3E%3Csld
>>>>>>> %3AName%3Equery%3C%2Fsld%3AName%3E%3Csld%3AUserStyle%3E%3Csld%3AName%3
>>>>>>> Equery%3C%2Fsld%3AName%3E%3Csld%3AFeatureTypeStyle%3E%3Csld%3ARule%3E%
>>>>>>> 3Cogc%3AFilter%3E%3Cogc%3APropertyIsEqualTo%3E%3Cogc%3APropertyName%3E
>>>>>>> geoidn%3C%2Fogc%3APropertyName%3E%3Cogc%3ALiteral%3ENL.IMRO.0184.EP127
>>>>>>> 818521-00%3C%2Fogc%3ALiteral%3E%3C%2Fogc%3APropertyIsEqualTo%3E%3C%2Fo
>>>>>>> gc%3AFilter%3E%3Csld%3APolygonSymbolizer%3E%3Csld%3AFill%3E%3Csld%3ACs
>>>>>>> sParameter%20name%3D%22fill%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%
>>>>>>> 3Csld%3ACssParameter%20name%3D%22fill-opacity%22%3E0.4%3C%2Fsld%3ACssP
>>>>>>> arameter%3
>>>>>>> E%3C%2Fsld%3AFill%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D
>>>>>>> %22stroke%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParamet
>>>>>>> er%20name%3D%22stroke-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3E%3Csl
>>>>>>> d%3ACssParameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParamet
>>>>>>> er%3E%3C%2Fsld%3AStroke%3E%3C%2Fsld%3APolygonSymbolizer%3E%3Csld%3ALin
>>>>>>> eSymbolizer%3E%3Csld%3AStroke%3E%3Csld%3ACssParameter%20name%3D%22stro
>>>>>>> ke%22%3E%23FF00FF%3C%2Fsld%3ACssParameter%3E%3Csld%3ACssParameter%20na
>>>>>>> me%3D%22stroke-opacity%22%3E0.4%3C%2Fsld%3ACssParameter%3E%3Csld%3ACss
>>>>>>> Parameter%20name%3D%22stroke-width%22%3E2%3C%2Fsld%3ACssParameter%3E%3
>>>>>>> C%2Fsld%3AStroke%3E%3C%2Fsld%3ALineSymbolizer%3E%3C%2Fsld%3ARule%3E%3C
>>>>>>> %2Fsld%3AFeatureTypeStyle%3E%3C%2Fsld%3AUserStyle%3E%3C%2Fsld%3ANamedL
>>>>>>> ayer%3E%3C%2Fsld%3AStyledLayerDescriptor%3E&SRS=EPSG%3A900913&BBOX=625
>>>>>>> 312.21905694,6921632.3781404,627462.0104771,6922637.4056294&WIDTH=1800
>>>>>>> &HEIGHT=841 any help greatly appreciated, MArco
>>>>>>> _______________________________________________
>>>>>>> mapserver-users mailing list
>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
