[mapserver-users] DXF layer definition in mapfile
Dejan Gambin
dejan.gambin at coin.hr
Thu Mar 4 10:24:26 EST 2010
Since DXF driver has been made, I would like to show a DXF file on the map. Is this possible? What syntax do I have to use to make it work?
I have tried defining it similar to dgn syntax, but it doesn't work. I get: "msOGRFileOpen(): Open failed for OGR connection in layer `layer_name'. File not found or unsupported format.".
ogrinfo works fine on this file. For example:
root# ogrinfo -so test.dxf entities
INFO: Open of `/Library/WebServer/Documents/demodata/test.dxf'
using driver `DXF' successful.
Layer name: entities
Geometry: Unknown (any)
Feature Count: 888
Extent: (5416785.444339, 5009511.330286) - (5431570.527990, 5024296.413476)
Layer SRS WKT:
(unknown)
Layer: String (0.0)
SubClasses: String (0.0)
ExtendedEntity: String (0.0)
Linetype: String (0.0)
EntityHandle: String (0.0)
Text: String (0.0)
My layer definition looks like this:
LAYER # dxf
NAME "layer_name"
GROUP "group_name"
STATUS ON
TYPE LINE
METADATA
"DESCRIPTION" "Description"
END
CONNECTIONTYPE OGR
CONNECTION "/Library/WebServer/Documents/demodata/test.dxf"
DATA "0"
STYLEITEM "AUTO"
CLASS
NAME "All"
END
PROJECTION
"init=epsg:31275"
END
END
I also tried without DATA and STYLEITEM keywords but doens't help.
Any hint?
Thanks very much
regards, dejan
