[mapserver-users] WMS TIME parameter slow
Heiko Schröter
schroete at iup.physik.uni-bremen.de
Wed Mar 10 10:22:29 EST 2010
Hello,
using mapserv (5.6.1) with PostGIS (8.3) and accessing ten-thousands of geo locations in the PostGIS db results in very slow speed when using the WMS TIME parameter:
(in this example the number is about 4000 datapoints for this day, timing measurements with DEBUG OFF).
1) Very fast using FILTER, approx. 5 seconds:
CONNECTION "user={BF961C25A57BA226} password={C9748CA35D48D049} dbname={6B40E65B12B92106} host=localhost"
DATA "geocoord from xyz_ref using unique datum"
VALIDATION
'filter' "^datum >= '[0-9]{4}-[0-9]{2}-[0-9]{2}' and datum <= '[0-9]{4}-[0-9]{2}-[0-9]{2}'"
END
FILTER "datum >= '2007-12-10' and datum < '2007-12-11'"
2) Very slow using WMS TIME, approx 210 and more seconds:
(Leaving the VALIDATION/FILTER on or leaving out 'using unique datum' doesn't change a thing)
METADATA
"wms_timeextent" "1970-01-01/2030-12-31"
"wms_timeitem" "datum"
"wms_timedefault" "2007-12-10/2007-12-11"
"wms_title" "xyz_r"
"wms_srs" "init=epsg:-1"
END
The MS ERRORFILE is very noisy spilling out all datapoints when running 2). This does not happen when running 1).
Database is the same. No other changes have been made.
Why is mapserver so slow when using the WMS TIME parameter ?
It would be nice to stick to the "official" WMS configuration and not to introduce a "vendor specific" workaround.
Thanks and Regards
Heiko
/var/www/localhost/cgi-bin/mapserv -v
MapServer version 5.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
A complete Layer definition:
LAYER
EXTENT -180 -90 180 90
CONNECTIONTYPE POSTGIS
NAME "SACURA_REF_R"
PROCESSING "CLOSE_CONNECTION=DEFER"
OPACITY 60
STATUS ON
METADATA
# "wms_timeextent" "1970-01-01/2030-12-31"
# "wms_timeitem" "datum"
# "wms_timedefault" "2007-12-10/2007-12-11"
"wms_title" "xyz_ref_r"
END
PROJECTION
"init=epsg:4326"
END
VALIDATION
END
TYPE POLYGON
SIZEUNITS meters
CLASS
DEBUG OFF
NAME "xyz_ref_class"
STYLE
OUTLINECOLOR 0 0 0
COLOR [rfarbe]
END
END
END # Layer
