[mapserver-users] runtime substitution not working
Joshua Hevenor
jhevenor at rogers.com
Sun Mar 14 20:03:14 EDT 2010
I see what Ben was worried about and what you're trying to do. I haven't done a lot of variable substitution but I have done a lot of head scratching to when queries don't work as expected. A couple things that might shed some light you could try:
"like '%spp%'" and pass &spp=%TAR%
If you're looking for a string containing TAR. It might confirm that the double %% are being misinterpreted.
Or you could try if this is the case and you want to force the wildcards at the mapfile level.
"like '%' || '%spp%' || '%"'
Josh
--- On Sun, 3/14/10, pcreso at pcreso.com <pcreso at pcreso.com> wrote:
Subject: Re: [mapserver-users] runtime substitution not working
To: mapserver-users at lists.osgeo.org
Date: Sunday, March 14, 2010, 1:29 PM
Hi Ben...
I have it working in other setups fine - just this one won't behave.
If I use "like '%spp%'" & pass &spp=TAR, then the query that gets run is
"like 'TAR', which is basically an un-indexed =
I need a "like '%TAR%'" in the SQL hence the double % sign. I have this working elsewhere fine (but with different versions of mapserver & Postgis)
Capitalisation might be the problem... I'll try that...
Thanks,
Brent
--- On Sun, 3/14/10, Ben Madin <lists at remoteinformation.com.au> wrote:
> From: Ben Madin <lists at remoteinformation.com.au>
> Cc: pcreso at pcreso.com
> Date: Sunday, March 14, 2010, 1:25 PM
> G'day Brent,
> It might not matter, but you have double %% in the DATA
> statement you have passed,
> and for whatever reason - I recevied advice from this list
> or OpenLayers list - I have all my variable names
> capitalised in the query:
> WHERE transferdate
> >= '%STARTDATE%' AND transferdate <= '%ENDDATE%'
> AND
> line_geom IS NOT NULL
> AND
> sourceshire NOT LIKE destinationshire
> AND
> sourceshire LIKE '%SOURCESHIRE%'
> So I hope these might help if Steve's solution didn't
> cheers
> Ben
> On 13/03/2010, at 24:00 , mapserver-users-request at lists.osgeo.org
> wrote:
> > I'm obviously doing something wrong, but can't see
> what it is... I have a Postgis table of species occurences
> & I want to pass a variable to the mapfile to select
> which speciesusing runtime substitution.
> > The relevant DATA statement (joining species in the
> catch to locations in the station) in the mapfile is:
> > DATA "startp from (select c.id, s.startp, s.trip_code,
> s.station_no, c.species,
> c.weight
> from t_station s, catch c
> where
> s.station_no=c.station_no
> and c.species ilike
> '%%spp%%')
> as myquery
> using unique id using
> srid=4326"
> > The query works in Postgis & in the mapfile (via
> QGIS) when I hard code the %spp% (eg, to 'TAR')
> > I'm using QGIS to open the layer, with the URL:
> > http://wms-dev/cgi-bin/mapserv?map=/srv/www/htdocs/mapdata/catch.map&spp=TAR
> > QGIS appends the request type, etc & it works with
> the hard coded "spp"
> > The mapfile also has:
> > METADATA
> > "wms_title" "species"
> "wms_srs" "epsg:4326"
> > "wfs_title" "species"
> > "wfs_version" "1.0.0"
> > "wfs_typename" "species"
> > "wfs_request_method" "GET"
> > "wfs_service" "WFS"
> > "spp_validation_pattern"
> '^[A-Z0-9][A-Z0-9][A-Z0-9]$'
> > END
> > The version I'm running is MapServer version 5.4.1
> > (so no default supported)
> > The docs say I can use shp2img to test runtime
> substitution in a mapfile, but I can't see how to invoke the
> substitution with the equivalent of a spp=TAR statement to
> test this.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100314/6403f219/attachment.html
