[mapserver-users] Oddball mapserver/ArcSDE issue
Paul Ramsey
pramsey at cleverelephant.ca
Thu Mar 18 14:33:13 EDT 2010
Russell,
Attach your patch to a ticket (http://trac.osgeo.org/mapserver) and
assign it to me (pramsey) and I'll ensure it's committed into the next
patch releases and major releases.
P
On Thu, Mar 18, 2010 at 11:03 AM, Russell McOrmond <russell at flora.ca> wrote:
> On Tue, 16 Mar 2010, Russell McOrmond wrote:
>> The segmentation fault is caused by using a string which is actually null
>> being returned from string functions, with the null then being used as if it
>> were a string.
>> See: http://trac.osgeo.org/mapserver/ticket/2988 "Check error returns
>> from mapstring functions."
> Sorry to be responding to my own messages, but wanted to report on
> progress.
> I added in some additional error return checking, and put some suggestions
> into the bug listed above.
> I created some additional error reporting on what the reason for the
> iconv() failure was (see path at end of message), and now I see "An invalid
> multibyte sequence has been encountered in the input" in the MS_ERRORFILE.
> While it is great to have mapserver not core dumping, I am still wondering
> if anyone has ideas of where to go next. I suspect there is something
> invalid in the data that is causing ArcSDE to send me strings that aren't
> valid UTF-16 characters. I don't know enough about ArcSDE or other ESRI
> software to know how to validate such things.
> Note: Please consider patches like the one below and/or the ones in the bug
> for future releases of mapserver. It would be great if Mapserver would
> output error messages rather than core dump.
> --- mapstring.c-orig 2010-03-17 16:43:19.000000000 -0400
> +++ mapstring.c 2010-03-18 11:54:02.000000000 -0400
> @@ -1504,8 +1504,8 @@
> char* msConvertWideStringToUTF8 (const wchar_t* string, const char*
> encoding) {
> #ifdef USE_ICONV
> - int bconvFailed = MS_TRUE;
> char* output = NULL;
> + char* errormessage = NULL;
> iconv_t cd = NULL;
> size_t nStr;
> size_t nInSize;
> @@ -1540,23 +1540,36 @@
> pszUTF8 = output;
> pwszWide = string;
> nConv = iconv(cd, (char **)&pwszWide, &nInSize, &pszUTF8,
> &nOutSize);
> - if ((size_t)-1 != nConv && nOutSize != nBufferSize)
> - bconvFailed = MS_FALSE;
> + if ((size_t)-1 != nConv && nOutSize != nBufferSize) {
> + switch (errno) {
> + case E2BIG:
> + errormessage = "There is not sufficient room in buffer";
> + break;
> + case EILSEQ:
> + errormessage = "An invalid multibyte sequence has been
> encountered in the input";
> + break;
> + case EINVAL:
> + errormessage = "An incomplete multibyte sequence has been
> + break;
> + default:
> + errormessage = "Unknown";
> + break;
> + msSetError(MS_MISCERR, "Unable to convert string in encoding
> '%s' to UTF8: %s",
> + "msConvertWideStringToUTF8()",
> + encoding,errormessage);
> + iconv_close(cd);
> + msFree(output);
> + return NULL;
> iconv_close(cd);
> } else {
> msSetError(MS_MISCERR, "Encoding not supported by libiconv
> (%s).",
> encoding);
> + msFree(output);
> return NULL;
> - if (bconvFailed) {
> - msFree(output);
> - output = NULL;
> - msSetError(MS_MISCERR, "Unable to convert string in encoding
> '%s' to UTF8",
> - "msConvertWideStringToUTF8()",
> - encoding);
> } else {
> /* we were given a NULL wide string, nothing we can do here */
> return NULL;
> Russell McOrmond, Internet Consultant: <http://www.flora.ca/>
> Please help us tell the Canadian Parliament to protect our property
> rights as owners of Information Technology. Sign the petition!
> http://digital-copyright.ca/petition/ict/ http://KillBillC61.ca
> "The government, lobbied by legacy copyright holders and hardware
> manufacturers, can pry control over my camcorder, computer,
> home theatre, or portable media player from my cold dead hands!"
> mapserver-users at lists.osgeo.org
