[mapserver-users] WMS TIME parameter slow
Yewondwossen Assefa
yassefa at dmsolutions.ca
Thu Mar 18 15:06:41 EDT 2010
Sorry to jump late on this.
The use of the date_trunc function for postgis layers (described
http://mapserver.org/ogc/wms_time.html) was from what I remember to
allow queries (on a timestamp field)
like time=2001-01-01 expecting to get back all values of the day
regardless of the time set. I have entered a bug on it
(http://trac.osgeo.org/mapserver/ticket/3382) to be able to review it
before the 6.0 release.
regards,
Paul Ramsey wrote:
> Sorry, there's not much more I can offer, you've done a great job
> debugging, but at the end of the day the SQL being generated by the
> WMS Time module is not great. Make sure to run 'ANALYZE' on your
> database so the planner has the latest stats.
> P.
> On Thu, Mar 11, 2010 at 5:59 AM, Heiko Schröter
> <schroete at iup.physik.uni-bremen.de> wrote:
>> Am Donnerstag 11 März 2010 14:35:53 schrieben Sie:
>> Paul,
>> thanks for staying at it. These timings i get with the variation of the theme. The second best is to cast 'datum::timestamp'. But still beeing 32times slower than just a trivial compare on the index as in 1). The slowest run is the brute force 'date_trunc' without cast 3). So to me this is a bit voodo why postgres refuses to scan the indices in proper speed in 2) and 3).
>> The maximum index scan i get with 'date_trunc' is a 'Bitmap Heap Scan' on the index with scenario 2).
>> Of what i have found inside the docs/google is that even when casting 'datum' inside postgres the request, here generated by MS, should or have to be casted as well which is not (at least by now).
>> Heiko
>> 1) The brute force compare:
>> sc_gis=# explain analyze select "datum","farbe",encode(AsBinary(force_collection(force_2d("rechteck")),'NDR'),'hex') as geom,"datum" from o_v20 where rechteck
>> && GeomFromText('POLYGON((-134.90506329114 -78.2278481012662,-134.90506329114 78.2278481012663,134.90506329114
>> 78.2278481012663,134.90506329114 -78.2278481012662,-134.90506329114 -78.2278481012662))',-1) and (datum >= '2007-12-10' and datum <= '2007-12-11');
>> <snip><snap>
>> Total runtime: 41.018 ms
>> (32 rows)
>> Now Create Immutable Index on our play table:
>> CREATE INDEX o_v20_y2007_date_trunc ON o_v20_y2007 (date_trunc('day', datum::timestamp without time zone));
>> 2)
>> sc_gis=# CREATE INDEX o3_v20_y2007_date_trunc ON o3_v20_y2007 (date_trunc('day', datum::timestamp without time zone));
>> ERROR: relation "o3_v20_y2007_date_trunc" already exists
>> scia_gis=# explain analyze select "datum","farbe",encode(AsBinary(force_collection(force_2d("rechteck")),'NDR'),'hex') as geom,"datum" from o_v20 where rechteck
>> 78.2278481012663,134.90506329114 -78.2278481012662,-134.90506329114 -78.2278481012662))',-1) and ((date_trunc('day', datum::timestamp without time zone) >= '2007-12-10' AND date_trunc('day', datum::timestamp without time zone) <= '2007-12-11'));
>> <snip><snap>
>> Total runtime: 1250.679 ms
>> (26 rows)
>> 3)
>> 78.2278481012663,134.90506329114 -78.2278481012662,-134.90506329114 -78.2278481012662))',-1) and ((date_trunc('day', datum) >= '2007-12-10' AND date_trunc('day', datum) <= '2007-12-11'));
>> <snip><snap>
>> Total runtime: 2329.380 ms
>> (23 rows)
>>> Good job getting this far on your own! Create a SQL wrapper function
>>> on top of date_trunc which *is* marked as immutable and you'll be able
>>> to build a functional index on it.
>>> P.
>>> On Thu, Mar 11, 2010 at 1:39 AM, Heiko Schröter
>>>> Am Mittwoch 10 März 2010 16:52:28 schrieb Heiko Schröter:
>>>> Done what has been suggested. The 'date_trunc' function forces sequential scans instead of using the indexed scans.
>>>> I've tried and failed:
>>>> sc_gis=# CREATE INDEX o_v20_y2007_date_trunc ON o_v20_y2007 (date_trunc('day', datum at time zone 'GMT'));
>>>> ERROR: functions in index expression must be marked IMMUTABLE
>>>> Probably the MS list is not the right place to ask.
>>>> But may be a kind soul has some pointers to more infos.
>>>> I admit that db's are not my field of experience and i'am still learning.
>>>> On the other hand it would be nice to have a hint about the indexing issue inside the MS docs when using the WMS Time extension.
>>>> Heiko
>>>> 78.2278481012663,134.90506329114 -78.2278481012662,-134.90506329114 -78.2278481012662))',-1) and (datum >= '2007-12-10' and datum <= '2007-12-30');
>>>> QUERY PLAN
>>>> Result (cost=0.00..585.37 rows=4420 width=450) (actual time=0.083..35.821 rows=5322 loops=1)
>>>> -> Append (cost=0.00..541.17 rows=4420 width=450) (actual time=0.067..13.852 rows=5322 loops=1)
>>>> -> Seq Scan on o3_v20 (cost=0.00..16.65 rows=1 width=55) (actual time=0.001..0.001 rows=0 loops=1)
>>>> Filter: ((rechteck && '0103000000010000000500000035884A47F6DC60C038D93310958E53C035884A47F6DC60C03FD93310958E534035884A47F6DC60403FD93310958E534035884A47F6DC604038D93310958E53C035884A47F6DC60C038D93310958E53C0'::geometry) AND (datum >= '2007-12-10'::date) AND (datum <= '2007-12-30'::date))
>>>> -> Index Scan using o3_v20_y2002_datum on o3_v20_y2002 o3_v20 (cost=0.00..8.28 rows=1 width=450) (actual time=0.012..0.012 rows=0 loops=1)
>>>> Index Cond: ((datum >= '2007-12-10'::date) AND (datum <= '2007-12-30'::date))
>>>> Filter: (rechteck && '0103000000010000000500000035884A47F6DC60C038D93310958E53C035884A47F6DC60C03FD93310958E534035884A47F6DC60403FD93310958E534035884A47F6DC604038D93310958E53C035884A47F6DC60C038D93310958E53C0'::geometry)
>>>> -> Index Scan using o3_v20_y2003_datum on o3_v20_y2003 o3_v20 (cost=0.00..8.28 rows=1 width=450) (actual time=0.006..0.006 rows=0 loops=1)
>>>> -> Index Scan using o3_v20_y2004_datum on o3_v20_y2004 o3_v20 (cost=0.00..8.28 rows=1 width=450) (actual time=0.005..0.005 rows=0 loops=1)
>>>> -> Index Scan using o3_v20_y2005_datum on o3_v20_y2005 o3_v20 (cost=0.00..8.28 rows=1 width=450) (actual time=0.005..0.005 rows=0 loops=1)
>>>> -> Index Scan using o3_v20_y2006_datum on o3_v20_y2006 o3_v20 (cost=0.00..8.28 rows=1 width=450) (actual time=0.005..0.005 rows=0 loops=1)
>>>> -> Index Scan using o3_v20_y2007_datum on o3_v20_y2007 o3_v20 (cost=0.00..458.27 rows=4411 width=450) (actual time=0.031..10.732 rows=5322 loops=1)
>>>> -> Index Scan using o3_v20_y2008_datum on o3_v20_y2008 o3_v20 (cost=0.00..8.28 rows=1 width=450) (actual time=0.010..0.010 rows=0 loops=1)
>>>> -> Index Scan using o3_v20_y2009_datum on o3_v20_y2009 o3_v20 (cost=0.00..8.28 rows=1 width=450) (actual time=0.006..0.006 rows=0 loops=1)
>>>> -> Index Scan using o3_v20_y2010_datum on o3_v20_y2010 o3_v20 (cost=0.00..8.27 rows=1 width=450) (actual time=0.005..0.005 rows=0 loops=1)
>>>> Total runtime: 37.760 ms
>>>> (32 rows)
>>>> 78.2278481012663,134.90506329114 -78.2278481012662,-134.90506329114 -78.2278481012662))',-1) and ((date_trunc('day', datum) >= '2007-12-10' AND date_trunc('day', datum) <= '2007-12-30'));
>>>> QUERY PLAN
>>>> Result (cost=0.00..55305.53 rows=2873 width=450) (actual time=1368.129..2371.436 rows=5322 loops=1)
>>>> -> Append (cost=0.00..55276.80 rows=2873 width=450) (actual time=1368.100..2339.593 rows=5322 loops=1)
>>>> -> Seq Scan on o3_v20 (cost=0.00..20.45 rows=1 width=55) (actual time=0.001..0.001 rows=0 loops=1)
>>>> Filter: ((rechteck && '0103000000010000000500000035884A47F6DC60C038D93310958E53C035884A47F6DC60C03FD93310958E534035884A47F6DC60403FD93310958E534035884A47F6DC604038D93310958E53C035884A47F6DC60C038D93310958E53C0'::geometry) AND (date_trunc('day'::text, (datum)::timestamp with time zone) >= '2007-12-10 00:00:00+01'::timestamp with time zone) AND (date_trunc('day'::text, (datum)::timestamp with time zone) <= '2007-12-30 00:00:00+01'::timestamp with time zone))
>>>> -> Seq Scan on o3_v20_y2002 o3_v20 (cost=0.00..2228.21 rows=123 width=450) (actual time=79.684..79.684 rows=0 loops=1)
>>>> -> Seq Scan on o3_v20_y2003 o3_v20 (cost=0.00..6587.07 rows=349 width=450) (actual time=238.174..238.174 rows=0 loops=1)
>>>> -> Seq Scan on o3_v20_y2004 o3_v20 (cost=0.00..7417.62 rows=378 width=450) (actual time=260.250..260.250 rows=0 loops=1)
>>>> -> Seq Scan on o3_v20_y2005 o3_v20 (cost=0.00..7328.16 rows=379 width=450) (actual time=264.246..264.246 rows=0 loops=1)
>>>> -> Seq Scan on o3_v20_y2006 o3_v20 (cost=0.00..7299.65 rows=383 width=450) (actual time=263.991..263.991 rows=0 loops=1)
>>>> -> Seq Scan on o3_v20_y2007 o3_v20 (cost=0.00..7642.97 rows=397 width=450) (actual time=261.744..297.122 rows=5322 loops=1)
>>>> -> Seq Scan on o3_v20_y2008 o3_v20 (cost=0.00..8583.06 rows=439 width=450) (actual time=472.648..472.648 rows=0 loops=1)
>>>> -> Seq Scan on o3_v20_y2009 o3_v20 (cost=0.00..6961.72 rows=361 width=450) (actual time=394.525..394.525 rows=0 loops=1)
>>>> -> Seq Scan on o3_v20_y2010 o3_v20 (cost=0.00..1207.89 rows=63 width=450) (actual time=65.417..65.417 rows=0 loops=1)
>>>> Total runtime: 2374.403 ms
>>>> (23 rows)
>>>>> Am Mittwoch 10 März 2010 16:42:02 schrieben Sie:
>>>>> Thanks for the hint.
>>>>> Hm, i thought 4000 out of 4.5 Millions datasets for the whole year in 5 sec would be not that bad ....
>>>>> The timing figure shall just show the huge difference between the two types of requests.
>>>>> I will follow your advice and test the db. And yes the db is indexed.
>>>>> Heiko
>>>>>> Firstly, 2 seconds is not fast, so you have another performance troll
>>>>>> beyond this one.
>>>>>> Secondly, it's impossible to know what's going on inside the database
>>>>>> without seeing the actual SQL being generated. Turn on statement
>>>>>> loggging in PgSQL and extract the SQL that is being run against the
>>>>>> database. Then you can put that into PgAdmin or psql and get EXPLAIN
>>>>>> ANALYZE results which will tell you why there's a problem, hopefully.
>>>>>> P.
>>>>>> On Wed, Mar 10, 2010 at 7:22 AM, Heiko Schröter
>>>>>>> Hello,
>>>>>>> using mapserv (5.6.1) with PostGIS (8.3) and accessing ten-thousands of geo locations in the PostGIS db results in very slow speed when using the WMS TIME parameter:
>>>>>>> (in this example the number is about 4000 datapoints for this day, timing measurements with DEBUG OFF).
>>>>>>> 1) Very fast using FILTER, approx. 5 seconds:
>>>>>>> CONNECTION "user={BF961C25A57BA226} password={C9748CA35D48D049} dbname={6B40E65B12B92106} host=localhost"
>>>>>>> DATA "geocoord from xyz_ref using unique datum"
>>>>>>> VALIDATION
>>>>>>> 'filter' "^datum >= '[0-9]{4}-[0-9]{2}-[0-9]{2}' and datum <= '[0-9]{4}-[0-9]{2}-[0-9]{2}'"
>>>>>>> END
>>>>>>> FILTER "datum >= '2007-12-10' and datum < '2007-12-11'"
>>>>>>> 2) Very slow using WMS TIME, approx 210 and more seconds:
>>>>>>> (Leaving the VALIDATION/FILTER on or leaving out 'using unique datum' doesn't change a thing)
>>>>>>> METADATA
>>>>>>> "wms_timeextent" "1970-01-01/2030-12-31"
>>>>>>> "wms_timeitem" "datum"
>>>>>>> "wms_timedefault" "2007-12-10/2007-12-11"
>>>>>>> "wms_title" "xyz_r"
>>>>>>> "wms_srs" "init=epsg:-1"
>>>>>>> END
>>>>>>> The MS ERRORFILE is very noisy spilling out all datapoints when running 2). This does not happen when running 1).
>>>>>>> Database is the same. No other changes have been made.
>>>>>>> Why is mapserver so slow when using the WMS TIME parameter ?
>>>>>>> It would be nice to stick to the "official" WMS configuration and not to introduce a "vendor specific" workaround.
>>>>>>> Thanks and Regards
>>>>>>> Heiko
>>>>>>> /var/www/localhost/cgi-bin/mapserv -v
>>>>>>> MapServer version 5.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>>>>>> A complete Layer definition:
>>>>>>> LAYER
>>>>>>> EXTENT -180 -90 180 90
>>>>>>> CONNECTIONTYPE POSTGIS
>>>>>>> NAME "SACURA_REF_R"
>>>>>>> PROCESSING "CLOSE_CONNECTION=DEFER"
>>>>>>> OPACITY 60
>>>>>>> STATUS ON
>>>>>>> METADATA
>>>>>>> # "wms_timeextent" "1970-01-01/2030-12-31"
>>>>>>> # "wms_timeitem" "datum"
>>>>>>> # "wms_timedefault" "2007-12-10/2007-12-11"
>>>>>>> "wms_title" "xyz_ref_r"
>>>>>>> END
>>>>>>> PROJECTION
>>>>>>> "init=epsg:4326"
>>>>>>> END
>>>>>>> VALIDATION
>>>>>>> END
>>>>>>> TYPE POLYGON
>>>>>>> SIZEUNITS meters
>>>>>>> CLASS
>>>>>>> DEBUG OFF
>>>>>>> NAME "xyz_ref_class"
>>>>>>> STYLE
>>>>>>> OUTLINECOLOR 0 0 0
>>>>>>> COLOR [rfarbe]
>>>>>>> END
>>>>>>> END
>>>>>>> END # Layer
>>>>>>> _______________________________________________
>>>>>>> mapserver-users mailing list
>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>> Dipl.-Ing. Heiko Schröter
>>>> Institute of Environmental Physics (IUP) phone: ++49-(0)421-218-62092
>>>> Institute of Remote Sensing (IFE) fax: ++49-(0)421-218-4555
>>>> University of Bremen (FB1)
>>>> P.O. Box 330440 email: schroete at iup.physik.uni-bremen.de
>>>> Otto-Hahn-Allee 1
>>>> 28359 Bremen
>>>> Germany
>> Otto-Hahn-Allee 1
>> 28359 Bremen
>> Germany
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
