[mapserver-users] help with AGG support
Julie Knoll
julieknoll at gmail.com
Wed Mar 24 11:04:23 EDT 2010
Actually we are using version 5.4.
I just tried compiling 5.6.3 and got a new set of errors on make
(non-related to agg)
mapstring.c: In function ‘msConvertWideStringToUTF8’:
mapstring.c:1542: warning: dereferencing type-punned pointer will break
strict-aliasing rules
mapstring.c:1544: error: ‘errno’ undeclared (first use in this function)
mapstring.c:1544: error: (Each undeclared identifier is reported only once
mapstring.c:1544: error: for each function it appears in.)
mapstring.c:1545: error: ‘E2BIG’ undeclared (first use in this function)
mapstring.c:1548: error: ‘EILSEQ’ undeclared (first use in this function)
mapstring.c:1551: error: ‘EINVAL’ undeclared (first use in this function)
make: *** [mapstring.o] Error 1
I then tried version 5.6.1 which compiled and installed perfectly, but when
trying to actually draw a map, it reported an error with my postgis layer:
[Wed Mar 24 09:49:48 2010].943741 msPostGISLayerGetItems(): Query error.
Error (ERROR: column "box" does not exist
LINE 1: ...om geom_cassidi_states where the_geom && setsrid(!BOX!,4269)...
) executing SQL: select * from (select the_geom, state_name, gid from
geom_cassidi_states where the_geom && setsrid(!BOX!,4269)) as foo where
false limit 0
so not sure what to do now ...
On Wed, Mar 24, 2010 at 9:52 AM, Alan Boudreault
<aboudreault at mapgears.com>wrote:
> Julie, what mapserver version are you using? AGG is already included in
> mapserver 5.6.x source. Just compile with "--with-agg" option. I'm not sure
> MS
> has been tested with agg 2.5.
> Alan
> On March 24, 2010 10:22:35 am Julie Knoll wrote:
> > Hi,
> > I have installed packages for agg-2.5 and agg-devel-2.5 on our server.
> > Compling mapserver using ./configure --with-php=/usr/include/php
> > --with-postgis --with-proj --with-geos --with-freetype --with-agg=/usr
> > works fine. However make returns the following errors. Could someone
> > please help? The server is CentOS 5.4
> > /usr/include/agg2/agg_pixfmt_rgba.h:1637: error: no type named ‘row_data’
> > in ‘class mapserv_row_ptr_cache<int>’
> > /usr/include/agg2/agg_pixfmt_rgba.h:1675: error: no type named ‘row_data’
> > mapagg.cpp: In member function ‘void
> > AGGMapserverRenderer::renderEllipse(double, double, double, double,
> double,
> > agg::rgba8&, agg::rgba8&, double)’:
> > mapagg.cpp:299: error: ‘class agg::path_storage’ has no member named
> > ‘transform’
> > mapagg.cpp: In function ‘void msCircleDrawShadeSymbolAGG(symbolSetObj*,
> > imageObj*, pointObj*, double, styleObj*, double)’:
> > mapagg.cpp:1077: error: ‘class agg::path_storage’ has no member named
> > ‘transform’
> > mapagg.cpp:1101: error: ‘class agg::path_storage’ has no member named
> > ‘transform’
> > mapagg.cpp:1144: error: ‘class agg::path_storage’ has no member named
> > ‘transform’
> > mapagg.cpp:1177: error: ‘class agg::path_storage’ has no member named
> > ‘transform’
> > mapagg.cpp: In function ‘void msDrawMarkerSymbolAGG(symbolSetObj*,
> > imageObj*, pointObj*, styleObj*, double)’:
> > mapagg.cpp:1300: error: ‘class agg::path_storage’ has no member named
> > ‘transform’
> > mapagg.cpp: In function ‘void drawPolylineMarkers(imageObj*, shapeObj*,
> > symbolSetObj*, styleObj*, double)’:
> > mapagg.cpp:1426: error: ‘class agg::path_storage’ has no member named
> > ‘transform’
> > mapagg.cpp:1427: error: ‘class agg::path_storage’ has no member named
> > ‘transform’
> > mapagg.cpp:1428: error: ‘class agg::path_storage’ has no member named
> > ‘transform’
> > mapagg.cpp: In function ‘void msDrawLineSymbolAGG(symbolSetObj*,
> imageObj*,
> > shapeObj*, styleObj*, double)’:
> > mapagg.cpp:1713: error: ‘class agg::path_storage’ has no member named
> > ‘transform’
> > mapagg.cpp: In function ‘void msDrawShadeSymbolAGG(symbolSetObj*,
> > imageObj*, shapeObj*, styleObj*, double)’:
> > mapagg.cpp:1831: error: ‘class agg::path_storage’ has no member named
> > ‘transform’
> > mapagg.cpp:1878: error: ‘class agg::path_storage’ has no member named
> > ‘transform’
> > mapagg.cpp:1926: error: ‘class agg::path_storage’ has no member named
> > ‘transform’
> > make: *** [mapagg.o] Error 1
> > Thanks
> Alan Boudreault
> Mapgears
> http://www.mapgears.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100324/a7c375aa/attachment.html
