[mapserver-users] PHP MapScript: shape->classindex is always 0
Alan Boudreault
aboudreault at mapgears.com
Thu Mar 25 10:07:35 EDT 2010
Hi Peter,
If you are sure that the shape use the different classes you specified in the
mapfile (you probably see it in your map image), so I guess it could be a bug.
Please fill a ticket with a test case. Assign it to "aboudreault".
regards,
Alan
On March 24, 2010 06:38:49 am Peter Hopfgartner wrote:
> Hello
> As I interpreted this, classindex should point to the right class of the
> instantiated shape. Unfortunatly, classindex is always 0.
> As a test I have a LAYER with 2 classes,
> CLASS
> NAME 'class1'
> EXPRESSION (([class] eq 1))
> STYLE
> SYMBOL "circle"
> SIZE 7.0
> OUTLINECOLOR 0 0 0
> COLOR 0 128 0
> END
> END
> CLASS
> NAME 'class2'
> EXPRESSION (([class] eq 2))
> STYLE
> SYMBOL "circle"
> SIZE 7.0
> OUTLINECOLOR 0 0 0
> COLOR 0 0 128
> END
> END
> In the PostGIS database are 4 point, 2 with class=1 and 2 with class=2,
> the generated map image shows the expected colors.
> The following script:
> <?php
> $mapfile = 'test.map';
> $map = ms_newmapobj($mapfile);
> $layer = $map->getLayerByName('test');
> $status = $layer->open();
> $status = $layer->whichShapes($map->extent);
> while ($shape = $layer->nextShape())
> echo "index: {$shape->index}\tclassindex: {$shape->classindex}\n";
> $layer->close();
> the following output:
> index: 0 classindex: 0
> index: 1 classindex: 0
> index: 2 classindex: 0
> index: 3 classindex: 0
> which is not what I expected.
> Am I missing something obvious or is this a MapServer bug?
> Regards,
> Peter
Alan Boudreault
Mapgears
http://www.mapgears.com
