[mapserver-users] ANGLE [attribute]
Daiane Azevedo de Fraga
daiane.a.fraga at gmail.com
Wed Mar 31 12:44:10 EDT 2010
Exactly! Thank you very much!!
I was using a TrueType font (Arial), but the software that I use as the
interface was changing to Bitmap, because I was not stating explicitly that
it was TrueType.
Another detail: using TrueType, it should be explicit FONT attribute.
Thanks, thanks, thanks David!
Daiane
2010/3/31 Fawcett, David (MPCA) <David.Fawcett at state.mn.us>
> Are you using TrueType fonts for your label?
> My memory could be bad, but I believe that you can only do label rotation
> with TrueType fonts, not with the default bitmap fonts.
> David.
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Daiane Azevedo de
> Fraga
> *Sent:* Wednesday, March 31, 2010 8:07 AM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] ANGLE [attribute]
> Thanks Daniel!
> I'm trying to get the database an angle to the text of a layer of type 'annotation', but is not working.
> The LABLEITEM (database) works, but not the angle.
> Daiane
> Daiane Azevedo de Fraga wrote:
> >* Hello everyone!
> *>* I wonder if ANGLE accepts an attribute that comes from a table in a
> >* database, eg Oracle Spatial? Either he accepts only one attribute of a DBF?
> Yes, that should work for all connection types (but I didn't test oracle
> spatial specifically myself).
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100331/8c62661e/attachment-0001.html
