[mapserver-users] map file paths
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Nov 3 17:19:39 EDT 2010
See http://mapserver.org/ogc/wms_server.html#reference-section and there about wrapper shell script.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: David Hildebrand
Lähetetty: ke 3.11.2010 22:42
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] map file paths
Is there a way of abbreviating pathnames to the map file? For instance,
my URL to produce a map is
http://localhost/cgi-bin/mapserv.exe?map=//fileserver/PDP/Program_Dev/DH
ildebrand/geoprocessing_server/MapServer/sample.map&mode=map
In my apache configuration file I have
//fileserver/PDP/Program_Dev/DHildebrand/geoprocessing_server/ aliased
to /test/ but the alias does not seem to work with CGI. I'm just
wondering if there is a workaround so that I don't need to specify the
whole file path in my URL.
Thanks.
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <about:www.afsc.ca> <http://www.afsc.ca
<http://www.afsc.ca/> >
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
