[mapserver-users] map file paths
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Nov 4 01:36:18 EDT 2010
P Kishor wrote:
> So you have 15 copies of the binary floating around on your computer.
> What a nightmare. If you upgrade, you have to make 15 copies of the
> new version and replace the old version.
> What would happen when you publish the 150th geologic map?
> Use a single binary, and use a wrapper (or the env variable) to get
> the right query.
I do not believe there are handy wrappers for Windows and the only way I have been able to get SetEnvIf to work is to make copies of mapserv.exe with different names. I maintain a batch file about our services with lines like "COPY mapserv.exe WMS_service1" etc. and then I only need to run the batch after update and publishing the 150th service does not change anything.
-Jukka Rahkonen-
