[mapserver-users] dynamic coloring in mapserver?
Brent Fraser
bfraser at geoanalytic.com
Thu Nov 4 17:33:58 EDT 2010
Mukesh
As Bob pointed out you can "over-ride" the color in mapserver's map
configuration file with a CGI variable. You can also have the STYLE
object in the map configuration file reference a color value stored as
an attribute value in the DBF. See http://mapserver.org/mapfile/style.html:
COLOR [r] [g] [b] | [attribute]
Color to use for drawing features.
[/Attribute/] was introduced in version 5.0, to specify the
item name in the attribute table to use for color values. The
hard brackets [] are required. For example, if your
/shapefile/'s DBF has a field named "MYCOLOR" that holds color
values for each record, your STYLE object for might contain:
STYLE
COLOR [MYCOLOR]
OUTLINECOLOR 150 150 150
END
Or better yet store the geometry and attributes in a PostGIS database to
avoid any file/record locking problems if you want the user to be able
to persistently change the value.
Best Regards,
Brent Fraser
On 11/4/2010 3:21 PM, Mukesh Subedee wrote:
> Hi,
> I am new to map server. I have been playing with it and finding it
> interesting. I have a shape file with database containing different
> area (polygon) codes. Let's say I have x.dbf file for a x.shp file and
> it contains a row with polygon code (I don't worry about layers).
> I want to color one or more area as desired by the user. e.g. If a
> user desires to color area number 12 that corresponds to a region
> (polygon) in the map, the desired area should be colored with specific
> color.
> Is it possible to do such thing with MapServer? Is it possible to
> dynamically assign specific color to the polygon area with it?
> Thanks a lot!
> Mukesh
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101104/c7d76635/attachment.html
