[mapserver-users] WMS GetFeatureInfo returning no results with 5.6
Oliver Wesp
oliver.wesp at gmail.com
Fri Nov 5 04:34:03 EDT 2010
Dear List,
I'm trying to execute a GetFeatureInfo Request to an S57-File via OGR.
The Request works fine in 5.2.0 returning all the attributes.
Trying the same request and the same mapfile with Mapserver 5.6.1 or
5.6.5 I just get "Search returned no results.".
Did I miss some configuration changes from 5.2 to 5.6 or is something
else going wrong?
All this happens on a Windows Server 2003 Box.
Below is the mapfile.
Any help ist appreciated.
best regards,
Oliver
MAP
NAME WMS
STATUS ON
UNITS DD
EXTENT 5.3120 49.577 31 67
TRANSPARENT ON
IMAGETYPE PNG
DEBUG 5
CONFIG "MS_ERRORFILE" "c:\wms\logs\mapserver.log"
CONFIG "CPL_DEBUG" "ON" #turns on gdal debugging
CONFIG "PROJ_DEBUG" "ON" #turns on proj debugging
#config options fuer gdal
CONFIG OGR_S57_OPTIONS
"RETURN_PRIMITIVES=ON,RETURN_LINKAGES=ON,LNAM_REFS=ON,SPLIT_MULTIPOINT=ON,ADD_SOUNDG_DEPTH=ON"
CONFIG GDAL_DATA "c:\Programme (x86)\FWTools2.4.7\data"
RESOLUTION 96
OUTPUTFORMAT
NAME 'PNG'
DRIVER AGG/PNG #Ausgabe von GD auf AGG gewechselt, das GD Probleme
mit Transparenzen hat
IMAGEMODE RGB
MIMETYPE 'image/png'
EXTENSION 'png'
END
PROJECTION
"init=epsg:4326" #Standardprojektion. Alle moeglichen Projektionen
werden in WEB.METADATA.WMS_SRS gesetzt
END
WEB
METADATA
"wms_name" "WMS"
"wms_title" "WMS"
"wms_onlineresource"
"http://192.168.1.230/cgi-bin/mapserver/mapserv.exe?map=c:\wms\Mapfiles\master.map&"
"wms_srs" "EPSG:4326 EPSG:31466 EPSG:31467 EPSG:31468 EPSG:31469
EPSG:2397 EPSG:2398 EPSG:2399 EPSG:25832 EPSG:25833 EPSG:4258"
END
END
LAYER
NAME COVR
GROUP "OVERVIEW"
TYPE POLYGON
STATUS ON
CONNECTIONTYPE OGR
PROCESSING "CLOSE_CONNECTION=DEFER"
CONNECTION "c:\s57\ENC\DE110000.000"
DATA "36"
FILTERITEM 'PRIM'
FILTER '3'
CLASS
NAME "Coverage"
STYLE
COLOR 203 205 127
OUTLINECOLOR 0 0 0
END
END
PROJECTION
"init=epsg:4326"
END
DUMP TRUE
TEMPLATE dummy.html
METADATA
"wms_abstract" "Coverage"
"wms_title" "Coverage (COVR)"
"wms_include_items" "all"
"wms_srs" "EPSG:4326"
END
END
END
