[mapserver-users] draw polygons ordered by field ? (from File
System)
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Tue Nov 9 08:27:20 EST 2010
The only way I know of is to use the sortshp utility.
http://mapserver.org/utilities/sortshp.html
Best regards,
Bart
> Hi All,
> Reading a shapefile (ESRI/MapInfo) from FS with polygons overlapping. Each
> polygon is drawn with a different color based on a field called RISK.
> Is it possible define an order on how the polygons are drawn ? Say for
> example to draw the polygons with field "RISK" 0 first, then with "RISK"
> =1
> and so on...
> I know that using PG we can use "Select * from XXX order by RISK"
> Is there any way to do that using ESRI/MapInfo files ?
> Thanks
> Sebastian E. Ovide
> mapserver-users at lists.osgeo.org
